Mitsubishi dlp 50'' TV flickers on top and left from time to time. Any ideas? Color is good sound is good, balance of screen seems to be fine. Does not do this all the time.
    Scholar:
  • 130 Answers
This could have something to do with the video board, your cable box, or DVD player, or it could be the DLP chip.
If it doesn't do this all the time, I'd take note of when it does occur. Figure out what you're watching, how you're watching it (DVR, Cable, DVD), and then even play around with swapping the cables first.
Then you can narrow it down to the DMD board or the video board. Those can be costly, so you want to rule out all other possibilities first.
Posted on Feb 05, 2010
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
After about an hour or so watching the tv the screen starts to flicker. I just changed the bulb, thats seems to have delayed the problem. Any advice?
mgs62872,
Is there any noise associated with the times that the unit flickers? Samsungs are notorious for losing the color wheel. I have replaced many and they usually make a high pitched whining sound. It could be high enough of a frequency that you may not hear it. If the lamp is new and the old lamp did not shatter or short out before you changed it I would say that the ballast is fine and I would change the color wheel. You will have to at some point as this is the weak point with the Samsung units. I have at tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which will walk you through the process as well as identify places to purchase the parts at the best price.
Thank you for using FixYa and for the great rating. Great ratings help keep experts solving everyone's problems. Thank you.
hardrocko
Nov 13, 2010 | Samsung SP50L6HX 50" DLP HDTV
Flickering screen, loud buzzing sound, self boot down.
Color wheel bad. Makes rumbling sound. Bad bearings. Has to spin about 10,000 RPMs and sync to DLP chip. Here: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5933777&smodel=HLR5067WX/XAA
May 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
SAMSUNG HD DLP HLN5065 50" TV
The problem of your DLP TV is a defected color wheel,replaced that so it will works normal again.
Hope it may help you;
Regards,
VOTIT
Sep 22, 2008 | Samsung DLP HL-P5663W 56" TV
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
