Question about Panasonic NN-S335 800 Watts Microwave Oven
My panasonic genius sensor 1300w microwave door is locked and will not open, all other functions were working normally. How do I unlock it ?
SOURCE: Panasonic Genius 800w locked
press start 3 times to lock and 3 times to unlock...hope that helps
Posted on Jul 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: my panasonic genius sensor microwave says lock.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
You can download most Panasonic owner's manuals here. It will tell you how to turn off the Child Lock.
Posted on Jun 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Genius Sensor 1300W
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Aug 30, 2009
  • 1531 Answers
SOURCE: shuts off after 15 seconds
sounds as if the magnetron has gone bad.this part of the machine is still under a warranty,and you need to call for a service technician to look at it.
do not use the unit until you get someone to look at it and or replace it.
Posted on Jan 31, 2010
Something in the door is causing microwave to shutoff. Sensor is on, but then shuts down unless,also you hold a certain pushing in the button.
Adjust the latch switch assembly to make sure that the door hooks engage with the switches. Loosen the 2 phillip screws holding the assembly and slide back and forth to adt. Retighten when the door hooks are making solid contact with the switches.
Dec 15, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Turn off demo mode
Unplug it if doesnt its work it may be the pc board
Sep 13, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
I have a panasonic microwave genius protege type AP104A which will not always work after closing the door
Closing the door operates a switch or switches which function as an interlock to prevent the oven from starting unless the door is closed completely. The switch or switches may be defective or misadjusted. Also, the door may not be closing properly to close the switch(es).
Dec 07, 2013 | Panasonic Microwave Ovens
My Panasonic 1300w microwave will not turn off. It doesn't cook but won't turn off without actually unplugging it or opening the door and leaving it open. Any help?
You may have a shorted door switch or a shorted relay on the control board.
You can see a help file on door switches here.
Dec 01, 2012 | Panasonic NN-SN657SMicrowave Oven
Where can I find manual for Genius Sensor 1300w
http://service.us.panasonic.com/OPERMANPDF/NNSN657S.PDF
Feb 07, 2011 | Panasonic NN-SN657SMicrowave Oven
How do I unlock the child lock on my Panasonic Genius Microwave?
March 2009 press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
Apr 01, 2010 | Panasonic NN-T888S Convection/Microwave...
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic genius 1300w starts and stops
model # PeB2060smiss- not working at all. What would think is the problem?
Nov 09, 2009 | Panasonic Microwave Ovens
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
Panasonic NN-S335 800 Watts Microwave Oven Logo
445 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
