Question about Refrigerators
Light inside the refrigerator not working. Bulb tests OK. Checked the socket with a non-contact circuit tester and there is no response. At the switch there is indication of power.
  • kurt_rentel1 Feb 05, 2010
    Worked great. The light is on! A paint can opening tool was great to bend up the base contact.
  • Refrigerators Master
  • 8,220 Answers
I would kill power and then bend the base up a hair to make better contact with the light bulb and retry. Post a model number for a better answer.
Posted on Feb 05, 2010
No power to left rear turn/ brake light
Check the display. Ask a helper to step on the brake pedal while you check the lights from the rear. If no lights appear, check the fuse that connects the brake lights. The owners manual will show the location of the fuse box and which fuse is for the brake lights. Pull out the fuse and look at the wire in the central window. If the wire is broken, replace the fuse. Make sure the new fuse is not blown, and carries the same amperage.
Take note of lights that are out, if any are working. The problem may be cured by replacing the bulb in a brake light that's out. A burned out bulb has a broken filament and a dark brown spot on one side. Check the owners manual for bulb type.
Check the circuit if replacement bulbs and fuses do not restore the lights. Find the wiring diagram in the vehicle assembly manual. The circuit for the brake lights runs from the battery to the fuse, to the pedal switch, to a connection plug, to the lights. The circuit has to be checked with a volt tester at all points.
Check the battery power and the light on your volt tester. Turn the ignition key far enough to activate the electrical systems. Turn on the lights to check for battery power. If the battery has power, ues it to check the volt tester. Put the black lead (the ground) from the volt tester on the negative battery terminal. Briefly touch the red tester light on the positive terminal. The light on the volt tester should flash brightly.
Test the wiring to the fuse. Clip the ground wire to solid metal near the fuse. Touch the light tip to both sides of the fuse. Both should light the tester. If neither side lights, the wire between the battery and fuse is bad. If only one side lights, the fuse is blown.
Test the switch and wiring. Touch the light tip of the tester to both terminals on the brake pedal switch without putting any pressure on the pedal. One should carry power and the other should not. When both show power, the switch is stuck and the brake lights are always on. If neither shows power, the wiring between the fuse and the switch is bad. Now check both switch terminals while the pedal is depressed. Both sides should light the tester. If not, the switch is bad.
Check the connection plug. Unplug the connection and refer to the vehicle manual to identify the brake light wire. Touch the tester light on the brake light wire at the inner socket on the battery side. If the tester lights, the power is flowing to this point. If not, the wire between the plug and the pedal switch is bad.
Check the socket. Plug in the connector plug and remove the bulb. Touch the contact inside the socket. If the tester lights, the socket is good. The socket and wire running to the plug should be replaced if the tester doesn't light.
Check the bulb with the ground wire. The bulb must be in its socket. The ground wire running to the socket should be black or brown. Stab the tester through the insulation. If the tester lights, the bulb is good. Replace the bulb if it doesn't light.
Check the ground wire. Remove some of the insulation around the ground wire. Twist one end of the extra wire around the exposed ground wire. Touch the other end to a solid piece of metal. If the brake light comes on, the ground wire is bad.
Best Offer 2013 11 MB SD Connect Compact C4 Star Diagnosis with WiFi
Oct 13, 2014 | 2000 Ford Expedition
Front side marker / turn signal wiring diagram for 1997 crown vic LX. Both directionals works, but parking light on driver side dosn't. passenger side works fine . 3157 bulb and only 2 wires to socket !...
Verify:
- the bulb socket are still wired soundly on the back side
- contacts inside socket are still intact.
- wires are not frayed/broken (entire length)
- the actual bulb is good
-all ground wires are soundly connected
Oct 11, 2014 | 1997 Ford Crown Victoria
Taillight??
Inspect the bulb and the socket for overheating. If one of the internal tabs are broken, missing, or bent. The connection will not be good enough to handle the load of the bulb. What type of tester are you using to confirm that your tail-light socket has continuity? I ask because unless you are using a test-light (with an incandescent bulb), the test isn't accurate. You need to confirm that the Load wire and the Ground wire are undamaged. Please write back. Let me know if that helps, good luck.
Apr 25, 2014 | 2005 Jeep Grand Cherokee
One metal contact not working in light assembly of right rear turn signal
Must be a bad socket, anyway. If I understand, you are talking about the two contact points inside the socket? On a two filament bulb, one contact is for the smaller filament park light, and the other contact is for the turn signal and/or brake light, the larger filament inside the bulb. So if you tested with a test light, with park lights on, one contact only would light up the tester. If you pressed the brakes, the other contact would have a steady light on the tester. That same contact would or should have a blinking test light, with the key on and the right turn signal on.
I would not be surprised if you need a new assembly. Possibly, too, the ground for that side needs checked.
Jan 29, 2014 | Jeep Grand Cherokee Cars & Trucks
1997 GMC Sierra p/u. Brake light & blinker out. Lamp & fuse ok.
you probably got the wrong bulb
those are usualy a different number higher wattage, they look exactly like an 1127 but are a 2027 or even a 3027 check the bulb base it has the number printed on it
Aug 30, 2009 | 1997 GMC Jimmy
Tail lamps, turn signals work, running lights work-no brake light
check the socket for 12v if there is 12 volts then your terminals inside the socket are not making contact with the bulb terminal replace the socket
Jun 06, 2009 | 1983 Ford F 250
02 Nissan Altima Sunroof won't work
circuit tester to the switch when pressed should show a charge if no charge than bad contacts in switch ... if charge than the problem lyes in the motor by the sunroof. can make a tester from an old turn signal bulb a socket just ground 1 wire off the socket and use the other wire as test probe. if you find this info helpful please rate
Apr 19, 2009 | 2002 Nissan Altima
Left rear brake light stopped working but bulb and fuses are OK.
take the bulb back out have someone sit in car apply brake get your self a circuit tester and check to see if this circuit is carrying efficient 12 volt current! some times in cold weather these bulbs get hot with long period of breaking and when released condensate and rust begins and you get what you have perhaps bad socket! this would be a ideal location to begin and probably end,
Jan 03, 2009 | 1999 Audi A4
Brake and tail lights
Pull the light bulbs and test the bulb sockets, use a 12 volt test light probe, kinda looks like an ice pick or awl, with the clip lead of the test light at a good ground, probe the contacts to the bulb with the lights on, if the test light glows then there is 12 volts to the socket, if not probe the wire to the socket for power, if it is ok then replace the bulb socket, the dealer can supply this part. 1st though make sure the bulb is good, swap out a working bulb to the non working side,
Aug 06, 2008 | 1998 Ford Windstar
Front light will not work
Before you go any farther stop. Unplug the refrigerator for the wall receptacle then look into the light socket (use a mirror if necessary), now see that contact point in the bottom of the socket? Raise that contact point to where it will ouch the bulb when you screw it back in. Now screw in the bulb plug in the refrigerator and open the door. Did I do OK ?
supertechks
Nov 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
