Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
Heat can i connect slantfin base boards to a 75 gallon hotwater heater
  • 8,404 Answers
What is it that you are trying to do? Do you have a piece of hot water baseboard heater and you want to 'power' it with an electric hot water heater?
Codes aside, I don't see why it would not work. You will have to put a circulator (and a temp control device) on it to move the water.
This is not going to be a very economical heating system.
Posted on Feb 05, 2010
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
Only have hot water when heat is on
A stuck divert-er valve yes replace head, and know this will not cause leaks leaks,leaks are caused by o seals worn and getting old ..and olives on connections replace the above as needed some times a quick tighten with rench will do it leaks that is
Sep 28, 2013 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
On A.O. Smith water heater model BTH 199 100 where is the heat sensor rod located ?
Parts list:
http://www.hotwater.com/lit/partslists/197728-004.pdf
Flame rod, flame sensor sits next to igniter inside combustion chamber. This can be cleaned with sandpaper. Do not touch with fingers. Purpose of flame rod is to detect whether ignition has caused actual, sustainable fire inside the combustion chamber.
If sensor is bad, or no ignition is detected after 2-3 attempts, then 'no ignition' error is given.
Bad gas control valve, bad-or-dirty flame rod-sensor, low gas pressure, misaligned rod, dirty combustion parts, etc
Service handbook:
http://www.hotwater.com/lit/training/316586.pdf
High gas pressure spikes can daMAGE gas control valve p7
Product manual:
http://www.hotwater.com/lit/im/com_gas/197727.pdf
Word-search for 'failure'
Low gas pressure. p14 and p54
1-3 trials before declaring 'ignition failure. p48
bad flame sensor (clean with sandpaper) #10 p58
unit must be grounded (check outlet with circuit analyzer) #12 p58
Sequence flow chart p59
Rough starts = ignition failure p60
Troubleshoot chart - ignition failure p62
Mar 12, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Oct 22, 2010 | Rheem Water Heaters
Ferolli HE 31C fires up fine, hotwater works, but ...
diverter valve fault most likely. when you call for central heating do you get 3 swiggley lines coming off radiator symbol in the boiler display if you do and not getting central heating then definitely diverter fault
May 20, 2010 | Quasar HQ2051TH Air Conditioner
Phone got wet now doesn't do anything
Thee's no magic button to push to fix it. Your best bet is to try to replace the base cord and inspect the contacts where it plugs in. Then you start phone surgery. It could be corrosion under the hookswitch or where the top half connects to the bottom half. A new(er) phone will probably cost you between $75 and $150. It tends to be beyond economic repair (BER) to repair electronics damaged by either smoke or water.
Carl
Nov 07, 2009 | Panasonic KX-T7730 Corded Phone
No constant hot water from baxi 105e
Im guessing this is a boiler with on demand hot water or a on demand heater, if so a common problem is most on demands can only supply 3-4gpm so if you have a low flow shower head running it will keep up if you exceed the gpm output rating which can be found either in tech. specs. or on name plate. Keep in mind a tub faucet usually supplys 6gpm. Im talking in canadian gallons if I remember correct it is about 1 litre smaller than a US gallon.
Solutions; holding tank circuit, flow restrictor PRV on hotwater line. None of which are great options, buyer be ware of this common problem when buying on demand. Buy a hi efficient condensing hot water tank instead in my opion then you have capacity and can also use for hydronic heating.
Dec 01, 2008 | Computers & Internet
Humidifier's reset light flashes on and off
Most likely it is the water sensing transistor (C1815) in the unit. This can be replaced but it would have to be by someone who knows how to repair electronic instruments. The cross for the C1815 transistor is NTE85 and sells for about $1.50.
Dec 02, 2007 | Slant Fin GF-210W 2 Gallon Humidifier
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
107 people viewed this question
Top Marley Heating & Cooling Experts
paulcarew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
