Question about Frigidaire FEQ332E Electric Dryer
Frigidaire FEQ332ES tumbles but does not heat up. Replaced the thermostat, did not solve the problem.
  • 254 Answers
Check ur breaker see if something is tripped dryer willl run on 120 but needs 240 to heat..
check ur element and also a thermal fuse, there might also be another thermosat that could be bad.
if gas check the ignitor, fuse, and thermostats
Posted on Feb 05, 2010
Frigidaire #FSE748GFS1 is tumbling fine, but feels (& Smells) Way Too Hot! Over-heating is what lead me to fixing a broken heating coil, so I assumed fixing it would solve the over-heating.
Sounds like a stuck thermostat or sensor.
Be VERY careful with this because it could burn-up.
For safety reasons I suggest trash it and buy a new one.
Nov 02, 2017 | Frigidaire Dryers
Frigidaire Dryer GLER341AS2, tumbles but not heating
I would say your right on track, check your heating coil when you locate it also...just in case.
Good luck,
Hope this helps...
Oct 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ332ES-It starts out ok, then trips the breaker, then no heat, continues to run but only blows cold air
sounds like your heat coil element is shorted, this coil is in the inside behind the drum..
replace coil and this will solve your problem, the coils break , you get no heat but voltage goes to heat elem that is shorted, trips breaker
Sep 16, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer heats, then quits
The thermostat that controls the heat has failed. Try one of the other settings on the timer switch ans see if it will heat, the different cycles use different thermostats.
Jul 01, 2009 | Frigidaire FGQ332ES Gas Dryer
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
My Fridgidaire feq332es dryer has stopped heating in certain cycles. I read the thread about the control thermostat, I think I can change this myself do you have someone who can give me some direction on...
Have you checked your duct and vent for lint clogs? If you vent is obstructed, it will cause the unit to shut down the heat. Try removing the duct hose and examine for lint clogs. Be sure to look into where duct connects to your dryer. Then take a look at the wall vent, both inside and outside the house as well. You might try that before replacing the thermostat.
Jun 08, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Runs Cold no heat ? Tumble Dryer
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Free tumbledryer repair videos
We have a Free full video library on appliance repair video’s
Jun 06, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Dryer won't heat
It could be a defective thermostat or heating element(In most of the cases it is the heating element).Open the service panel and check with a multi-meter for 115/220V on the heating element tags. If you can read 115/220V on its tags, it should be replaced. In case you can't read 115/220v on its tags, you should replace the thermostat. Good luck!
Sep 02, 2007 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ332E Electric Dryer Logo
224 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
