Question about Olevia 332V LCD TV
Trying to hook up a standard cable cord to my olevia 332-811 tv and can not find the connection spot for it on the tv am i missing something??
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Posted on Mar 29, 2008
freetek
  • 5568 Answers
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Posted on Aug 02, 2008
sandrew
  • 2961 Answers
SOURCE: hdmi cord
the HDMI cable sends all the audio and video down one line, and unscrambles scrambled high def content when required, and fits in the rear of the tv, the slot looks very similair to a usb slot.
If you cable box has an HDMI slot you can use that instead of a scart lead and choose HDMI on your tv output
Posted on Aug 18, 2008
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
  • 10 Answers
SOURCE: i hooked my olevia tv up to cable tuner box but cannot get a pict
Try switching throught the various video inputs on your tv until you get a picture.
Posted on Feb 03, 2009
How to get a signal from TV with Magnavox sdtv box directly hooked up to olevia tv
Hi. Tried a scart cable yet ? At least if there are scart in/out connections on both sets.
Oct 16, 2014 | Televison & Video
My olevia 42in tv now has a blue screen and a logo that says no signal. I have connected the cable to another tv and it works fine. What is my problem?
Check to make sure your tv is in the correct input/source. Are you trying to hook it up directly to a cable box or out of the wall and what connections are you using? If you are using the cable cord only then make sure your tv is on air/channel 3. If you are using a red,white,yellow connection then make sure your tv is on av1/av2 depending on which slot you have plugged it in on the back of your tv.
Apr 30, 2011 | Olevia Televison & Video
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
How do I hook up cable on my olevia tv
try this,
Audio Out of your Cable box colored RED and WHITE is connected to your TV's Audio In RED and WHITE. And connect the VIDEO out of your cable box YELLOW to your TV's VIDEO IN function c_getProfessional_AskGet_refreshPicture() { var imm = $("getProfessional_ask_fromprchat"); var val = false; if(imm) { val = $("getProfessional_ask_fromprchat").checked; } var pOn = $("c_AskGet_checkBoxOn"); var pOff = $("c_AskGet_checkBoxOff"); if(!pOn || !pOff) return; if (val) { pOn.style.display = ""; pOff.style.display = "none"; } else { pOff.style.display = ""; pOn.style.display = "none"; } } function c_getProfessional_AskGet_toggleImmediate() { var oImmediate = $("getProfessional_ask_fromprchat"); if(!oImmediate) return; var val = oImmediate.checked; oImmediate.checked = !val; c_getProfessional_AskGet_refreshPicture(); } c_getProfessional_AskGet_refreshPicture();
Oct 11, 2009 | Olevia LT32HVM 32 in. LCD Television
Problems hooking up an original nintendo
super nintendo set up to a magnavox standard tv
Oct 02, 2009 | Nintendo Super NES Console
DVD Hook up-Olevia 266-T11
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
Jan 14, 2009 | Olevia LT32HVM 32 in. LCD Television
Olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Oct 12, 2007 | Olevia LT32HVM 32 in. LCD Television
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Olevia 332V LCD TV Logo
142 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
