Question about Dishwashers
Kenmore elite dishwasher does not seem to be filling with water. all right lights come on but washer not washing
  • 572 Answers
Check and make sure water is on.
Posted on Feb 05, 2010
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ht4 front load washer
this seems to be a control panel issue. if water valve switches, try hot /cold water combos to see if it will start filling
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
Water seeps into my Kenmore Elite HE3 washer went is not in use. Does anyone else have this problem?
You are going to have to replace the water inlet valve. Since it's filling after the end of the wash the pressure switch is not going to detect the fill. The valve is not closing properly. It's an easy fix, remove the top and the valve is right there, te part number i think is 8181694
Mar 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Dishwasher wont fill up but can hear the motor....
dishwasher? could be the fill valve bad. or the float switch is stuck in the up position.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
