Question about Audiofonics ADF-241 Car Audio Amplifier
Power lights when my car is not on the three blue lights on top of the amp are still on, but the power light on the side of the amp is not. Is it normal for the three lights on top to stay on all the time?
  • drgnchld23 Feb 24, 2008
    Thanks. Problem solved.
  • 25 Answers
No that is not normal. That means your amplifier is still getting power. Try connecting your remote wire from your cd player, to an on / off switch (auto parts store) and from the on / off switch to the amplifier. When you turn your car off, turn the switch off and your amp will no longer have power.
Posted on Feb 24, 2008
Internal fuse
Amps getting power that's good it seems as though either you have a cross in your bridge or you fried your amp
Apr 02, 2014 | Hifonics Car Audio & Video
Where is the fuel pump relay on a 2008 jeep Liberty
Left side dashboard facing the door. Remove the oblong panel.
The fuse panel diagram is in your owners manual, if you don't have one, go to Jeep.com and download it for free.
Fuse Panel Description
Cavity Fuse Description
  • 1 15 Amp Blue Horn Relay, Power Sunroof Relay, Power Window Relay
  • 2 10 Amp Red Rear Fog Lights (Export Only)
  • 3 20 Amp Yellow Cigar Lighter
  • 4 10 Amp Red Headlight Low Beam Right
  • 5 10 Amp Red Headlight Low Beam Left
  • 6 20 Amp Yellow Body Control Module/Power Door Locks
  • 7 10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
  • 8 Spare
  • 9 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/ Cluster
  • 10 Spare
  • 11 15 Amp Blue Flasher
  • 12 15 Amp Blue Stop Lights
  • 13 10 Amp Red Body Control Module/ CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight Mirror/Light Bar Switch (Renegade Only)
  • 14 10 Amp Red PDC Fuel Pump/AC Clutch, Starter Relay/Engine Controller/Transmission Controller (Diesel Only)
  • 15 Spare
  • 16 20 Amp Yellow Power Outlet (Rear)
  • 17 15 Amp Blue Rear Wiper
Sep 02, 2012 | 2008 Jeep Liberty
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
The power light comes on then it give out
jl audio 12w7 with jl audio 1000.1
get a high volt capacitor 8 or more fared a breaker fuse 100amp .Best bet is to have an another battery hook up in back of truck for this kinda set up cause this amp really pulls alot of juice
May 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
When my car is not on the three blue lights on top of the amp are still on, but the power light on the side of the amp is not. Is it normal for the three lights on top to stay on all the time?
No it is not normal.. Normaly when lights stay on the problem is a constantly hot remote wire, but in your case you say the main power light is off.. Soo one can only assume the the problem is in the LED board it's self. This can happen when an amplifier is over heated, or has a poor soldering job. Now if you can hear white noise comming from your speakers with those lights on, then you have a simialr, but more serious issue. If it is just the lights, and not a powered up amplifier I would just let it go.. LED's draw very little power, and can't hurt anything. If the AMP is actualy staying on, I would get it repaired..
Jul 25, 2009 | Audiofonics ADF-241 Car Audio Amplifier
Power to the amp but the blue light doesnt turn on
probably a blown capacitor open it up and look at the capacitor see if any one of them are curvy on the top blowend
Jun 27, 2009 | Alpine MRP-M350 Car Audio Amplifier
Looking for audiofonics adf-240 owners manual.
There may be a loose wire to the lights, or the power supply or amp may have a problem. Do you have the amp mounted to your sub box directly? You shouldn't. The vibrations from the bub will kill the amp in a short amount of time. If it is noticeably weaker, you should check out all aspects of the system. For instance, if you have a dual voice coil sub, is one coil open? Is one channel on the amp bad? Is half of the power supply on the amp bad? hence half the power, and no lights?
Jun 11, 2009 | Audiofonics ADF-240 Car Audio Amplifier
Amp power protector comes on
Dis connect the sub then turn it on, don't let the wires touch or it will have a problem. If your lucky, it's just your sub that needs replaced. If not, your amp needs serviced. Rockford use to have a three year warranty... I'm not sure what they have now since mass merchants beat up the line. Hope this helps
Jun 02, 2009 | Car Audio & Video
Three blue lights blink
check you speakers and power source make sure all connection is correct
May 26, 2009 | JBL CS300.1 Subwoofer Mono Amp - 200W CS...
Power
BATTERY CABLE TO AMP B+
GROUND CABLE TO AMP GROUND
REMOTE WIRE CABLE FROM AMP CONNECTS TO BLUE REMOTE WIRE ON BACK OF CD DECK.
RCA JACKS GO FROM REAR OUTPUT OF CD DECK TO LOW FREQUENCY ON AMP INPUT.
Check Power cable fuse, check ground is grounded to non painted surface.
This is all you need to get it to work. If you still have a problem, then it is a bad capacitor inside the amp
Jan 30, 2009 | Car Audio & Video
Audiofonics ADF-241 Car Audio Amplifier Logo
108 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
