Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
I had the same thing, I have given up on using the small hoop and just do everything in the large hoop
Posted on Feb 10, 2010
  • 32 Answers
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Posted on Feb 05, 2010
SINGER QUARTET FOUR IN ONE HOOP ERROR
There are a couple of reasons that this can happen. First, download a patch on the singer Futura support site, www.futura-support.com. Download the patch, close the Futura program and double-click on the downloaded file. It may help with your error.
The second reason it can happen is because the USB plug on these machine is out a little too far, and the cable often doesn't seat quite as solidly as it should. Put the cable plug in the machine, making sure that it sits squarely and securely, and tape it in. When you unplug, do so from the computer side and leave it in
If you've applied the patch and taped the plug, the third reason might be the USB cable itself might have a loose wire, so that it works some time but not all the time. If that seems to be the case, try another cable.
Aug 05, 2014 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
I'm having problems with my singer futura quartet seqs-6000. While embroidering the machine begins to stich but the hoop does not move so all the thread gets caught under it in the bobbin. how do I f
for the hoop, you could turn off the machine and restart, or put in the big hoop and then select the small hoop for ur design. and get some TCL on all the bumps by joining the future group on FB. and don't forget to "pay it forward" back here on this site.
Nov 16, 2013 | Singer Sewing Machines
My Singer Futura keeps telling me that I have installed the small hoop and need to change it to the large hoop...but I have actually installed the large hoop. It is giving me an incorrect error message. I...
Make sure you have the latest software version. Current version you may check in About dialog under Help submenu and in the same submenu you wil find a function Live Update.
Also make sure you switch on the sewing machine either with the large hoop connected or without hoop. If sewing machine was switched on with the small hoop attached, it will provide this error message about wrong hoop.
Jan 30, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura 100 Embroidery machine...Need to cancel previous transmit
Had the same problem. Singer rep. solved this mystery in just min. after talking to her.
You can call singer company at 1-800-4SINGER. It will take a long time to get through, but they can talk you thru to resolve this matter. Or just visit singerco.com and go to F&Q section, #7 question.
Or you can email talktous@singerco.com (that's talk to us @ ...)
They answered my email the same day!
Hope this helps!
Jun 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Hoop errors
I have the same machine 1 year old ,check thet the hoop is on pins correctly and tight and that the large hoop is selected on the program.as these machins are verry sensetive.Hope this helps.
Lea
Jan 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Hoops
i found both hoops on this websit.....thesewingcenter.com...lrg...13.99, sm...12.99!!!!! it took me 2 months of web seaching to find tem
Jan 15, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Jun 03, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
181 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
