Question about Trendware TEW-452BRP Wireless Router (TEW452BRP)
Low outgoing internet
I inastalled my tew 452brp. Everything is ok,
but i can't send letters. The speed's become lower.
if i use direct connection (without router), the speed is normal
What is the problem? Broken router?
Also i have WAN connection type as fixed IP.
  • Anton_rus Feb 21, 2008
    Thanks for answer, but
    My incoming internet is ok. I can download files very quickly.
    I can't upload files. It takes me very much time to do it.
    I have problems only with outgoing.!!
    1) I think your first note about incoming internet, that is ok.
    2) My WAN connection type is fixed IP. In this type connection i can't adjust MTU
    3) The settings of my router for filtering are default.
    110,25 are open.
    The incoming/outgoing internt is ok without router.!
  • 46 Answers
If you are experiencing slow speed while connected to a router, there are a number of things that can cause that problem.
If its the router causing the problem it could be a bad router, or a setting on the router.
1.) first thing i would do is a traceroute to google.com so from a command prompt type tracert google.com and see if your few hops are high. if they are when the router is connected but not high when the router is disconnected, then we know its something with the router.
log into the router's configuration.
2.) on some models you can change the MTU size.
3.) make sure your not filtering any ports that you need such as 110, 25
start with those 3 steps and let me know how that goes.
Posted on Feb 21, 2008
How do I set up a secure password?
For trendnet
Your Trendnet wireless router lets you broadcast your home network across your entire house, so you can access the Internet in any room. This signal may be powerful enough to extend into neighbors' houses, where they could easily jump on the network if it is unsecured. To protect your network, set up Wireless Encryption Protocol, or WEP, to encrypt data and prevent access unless the user enters the correct password.
Type "http://192.168.0.1" in your Internet browser's address bar and press "Enter." Enter "admin" for the username and leave the password field blank. Click "Log In" to log into your Trendnet wireless router's administrative program. Click "Wireless" from the left pane of the "Basic" tab. Click "WEP" under the "Wireless Security Mode" section at the bottom of the screen. Enter your preferred password for the network. A strong password is made up of a random selection of numbers and letters. Click "Save Settings" at the top of the screen to save your WEP settings.
trendnet wireless router users guide
http://downloads.trendnet.com/tew-611brp/manual/ug_tew-611brp.pdf
Mar 26, 2013 | Trendware TEW-452BRP Wireless Router...
Wan and All LAN led bulbs are continuously on- Router not working
Straighten a Norwegian paper-clip, and insert one end into the small hole in the back of the router, to "reset" the router to its "factory" settings.
Or, spend $50, and replace the router.
Mar 26, 2010 | Trendware TEW-452BRP Wireless Router...
I am unable to connect to internet with laptop
you did not tell us how you connected to the internet by wireless or ethernet cables. but any way first check the setup of your modem router otherwise your network provider.
Oct 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
I have to disconnect and reconnect my TEW-432BRP router
Hi! please try to download the firmware of your router the routers website and upgrade the routers firmware.possible is. the firmware is corrupted..
Jul 18, 2009 | Trendware TEW-452BRP Wireless Router...
Slow internet connection
Sometimes ISPs (Internet Service Providers) upgrade information on their end to improve or alter something about their network. When this happens, routers have outdated information from the modem. You might want to try power cycling the modem and router. To do this, unplug the power from both the router and modem. After about 15-30 seconds, plug the modem back in. Wait for all of the lights to come on excluding the "PC Activity" light if it exists. Once the modem is registered with your ISP, plug your router back in and test your net speed using a site such as:
http://www.speedtest.net
If your service is back to normal, then you're all set. If it isn't, you may want to contact your ISP as there could be something wrong with the route traffic is taking from the node to your residence.
Mar 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
Computer not connecting to Router
Ok make sure your PC is connected to the router with a network cable for programming.
I noticed you said 192.168.1.1. I see an extra period just wanna make sure your typing it in correct
192.168.1.1
Ok so make sure the cable modem is plugged into the WAN on the router... Now connect another ethernet cable to the PC and the router. Reset the modem and router... wait a few mins and try to connect to the programming setup.
User name= admin Pass=admin
May 06, 2008 | Trendware TEW-452BRP Wireless Router...
TEW-452BRP - can't open a port (forward)
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Feb 23, 2008 | Trendware TEW-452BRP Wireless Router...
Slow outgoing internet
I would suggest checking in the router's admin panel. (Typical accessed by typing 192.168.1.1 or 192.168.0.1 into your address bar on your web browser. Type your password (if you do not know it check your owners manual for the default) and check to see if you have any firewall or port restrictions set.
Feb 21, 2008 | Trendware TEW-452BRP Wireless Router...
I can't get a connection
Try this WII setup guide:
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Feb 01, 2008 | Trendware TEW-452BRP Wireless Router...
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
Trendware TEW-452BRP Wireless Router (TEW452BRP) Logo
88 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
