Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
The heating coil has burned and separated, the handle is hanging by just one screw, and it opens almost on the floor level--2003, out of warranty...should I try to repair or just replace? thx, L
  • 129 Answers
Cost less to replace plus you have a warranty on new washer .
Posted on Feb 05, 2010
2003 grand marquis no heat engine temp normal other eatc ops all normal. is there an external heater control valve on the car?
  • Insufficient, erratic, or no heat
  • Low engine coolant level.
  • Engine overheating.
  • Plugged or partially plugged heater core (18476).
  • Temperature blend door binding/stuck.
  • Temperature blend door actuator (19E616).
  • Incorrect heater control valve (18495) operation.
  • Go To Pinpoint Test I .
Are the heater hose's going through the fire wall hot ?
I2 CHECK FOR HOT WATER TO THE HEATER CORE INLET HOSE WARNING: The heater core inlet hose will become too hot to handle and may cause serious burns if the system is working correctly. Allow the engine to reach normal operating temperature. Feel the heater core inlet hose.
  • Is the heater core inlet hose too hot to handle?
Yes GO to I4 .
No REFER to Section 303-03 to check cooling system function.
Jan 06, 2018 | 2003 Mercury Grand Marquis
How to replace handle on my GE JPB66WY4WW
normally you have to separate the 2 halves to attach an oven handle . tip door open till it stays open then lift off the hinges . lay flat on table top or floor and remove the screws around the outer edge . carefully separate it
Jun 09, 2016 | GE Ovens
Defrost and floor heat broke
Are you saying you don't have blower at all? Defrost, floor and panel are the only three separate modes you have. If it's not blowing at all and the fuses are good, check the wiring behind the glove box. There's a two wire plug with a large red wire just about center of the glove box opening that's known for burning out. If it is you'll see the burned spot on the connector or wont be able to disconnect it.
Jan 01, 2014 | 1999 GMC Sierra
I have a bissell pro heat carpet cleaner. It is model 25a3 and about 1 year old. no water comes out when I press the trigger to clean the floor. The tools attachment works fine, any ideas?
If you are getting water from the tool. But not at the floor the most likely problem is the heater is clogged with coagulated soap or minerals. You will need to separate the upper handle to get to the heater. Insure the machine is unplugged. Remove the cover from the heater making sure you don't lose the little gaskets on each screw. Clean the channels inside the heater and put the cover back on. Be aware of how you are Taking it apart so you will know how to reassemble it.
Oct 31, 2013 | Bissell 25A3 Proheat Upright Deep Heated...
My sq inverter works on cold air but when changed to heat stops working
Some models don't use the compressor as a heat pump for heating. And only use electrical heating coils in the heat cycle.If yours is one of those. It may be a burned connection at the thermostat or at the heater coil. Heater coils may have a safety diode or fusible link that opens if the heater coil is on but there is not enough airflow. If that is the problem you will need to remove the bad heater coil and replace it.
If your unit is a "true" heat pump the change over valve could be stuck or it's coil burned out. If you know what it looks like you can measure the voltage at the coil. If you have voltage sometimes you can whack the valve with a screwdriver handle to "unstick" the valve.
Jul 11, 2012 | LG Heating & Cooling
The brush on my halo model uv-st 3290 will not turn. I removed the brush cover and noticed that the cam shaft and gear that control the brush is not working either. is this a common issue?
im not a pro. but i am a tech. and have a few of these. here is what i have found.. if the brush and the uv-light both do not work.. you need to go a little deeper.. the handle when released and lowered like you are using it controls a safety switch. it is set up so that if you leave it running in one spot the brush wont tear up the carpet and the uv light cant stay on in one spot and burn the carpet. an example would be using the attachment. handle up and the brush n light are out. great idea, crappy switch in there.. it jams up. here is what you do. oh, also the rear wheels have safety switches on them, if one leaves the floor, light and brush go down..
FIRST UNPLUG, thenyou will take out the brush , belt,. keep the screws separate for each level , or item.. there different.. some Philips, some star.. next there will be another set of screws exposed. to get the lid off. everywhere you see a hole underneath, there is a screw, lol. i used a flashlight. also behind the rear wheels there is a screw tucked in there. just enough room to get at it. one on each side. once you get them all, lay it on the side. release the handle, and lean it back like your running it. leaving it on its side. looking from the top , in the back at the bottom of the handle 2 more screw. remove.. the lid is loose, but there is more.
on the base of the handle, there are 8 screws that let the base of the handle split. 4 phillips, 4 star they come out. when the handle splits there is a rubber gasket that sits where the suction tube splits. if it comes out. put it on the bottom half flat side to the floor..
ok, when you split that bottom half of the handle, the lid should move free.. if not there is still a screw in the bottom.. check that.. you dont really have to force the lid off.. when the lid is off, say wow, look at all that stuff, lol. i did. in the middle all the way in back you will have part of the handle still there connected to the base. in the front of the bottom inside the compartment there is a switch that is just a piece of plastic on a spring. thats what jams. if it is not jammed now, its because you rolled it around. work the handle up and down a few times, or, push the switch in a few times by hand. you will see what i mean. if it gets a little crooked it lams n the down or off position. then the brush and light dont work. you can plug it in and test it. it does stop the motor and kill the lights. only the vacuum motor will run. THERE ARE TWO SEPERTE MOTORS FOR THE BRUSH AND THE VACUUM PUMP.
just put it back together in reverse.. i got good at doing this. mine kept jamming up.
the other thing i have found is DO NOT LET THE BAG FILL ALL THE WAY. it does not burn out the vacuum motor. it looses power to the motor itself. the manual says something about an over heat protect. besides that button that never poops out. i believe that is the other bug with motors not running. however the company is closed. okeck now owns the rights to the halo vacuum. they say they changed it so they do not have any parts. and dont know where to get any. im still looking.. hope this helps you.
Oct 27, 2010 | Halo UVST Bagged Upright Vacuum
Honda Civic 2003. I need to separate (disassemble) the front door panel (plastic part in the inside side of the door) from the actual door so I can replace the lock cylindir. I have succeeded separating...
There might be hidden screws , usually at door handle , pluged with round plastic caps , or at door opening handle with small round cap.Look around and see what you can find .
Jun 08, 2010 | 2003 Honda Civic
My dryer doesn't produce heat. the coil ignites
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. In your machine, it appears Amana doesn't sell the coils as a separate item and the whole valve needs to be replaced. The part number is Y504091.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
At front, remove 2 screws near floor at the bottom of the lower front panel. Pull bottom of panel toward you and down. The gas valve should now be accessible on the left. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
Sep 17, 2009 | Amana ALG331RAW Gas Dryer
How can I level my refrigerator, my floor is not level.
place quarters under the un leveled side. that should do the job. Plus there should be adjustment screw outs on the bottom of the unit.
Jan 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dryer won't start
SOUNDS LIKE THE HEATING ELEMENT.
Oct 15, 2008 | Amana NDE2330AY Electric Dryer
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
49 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
