Question about Kenmore Elite 45986 Front Load Washer
My washer wont rinse it keeps saying f 21 - Kenmore Elite 45986 Front Load Washer
Unplug unit. Remove bottom front panel. The panel is held on by three screws. there will be a drain cap in plain view. Open it with a wet/dry vac and towels close by. Clean out the drain catch. If clean, use wet/dry to **** air through the drain nose and then blow air to check for obstructions. If clear and F21 error occurs again, go through previous steps and then remove the top of the black boot that is behind the drain and connected to it. Disconnect it from the tub side and check for blockage there. These steps should resolve approximately 98% of F21 errors.
Be very attentive to what goes into the washer!
Posted on Feb 06, 2010
  • 129 Answers
Clean out water pump
Posted on Feb 05, 2010
My washer wont work.its saying f:21
you will need to look in the manual that came with the machine, there should be a list of fault codes in the back, either that or call the manufacturer, they should to answer your questions, you'll find their contact details in the back of the manual
Jan 03, 2013 | Washing Machines
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
My washer keeps giving me a F-21 message! It won't kick into rinse or spin, but just gives me this message?
Whirlpool's 'F21' (along with 16, 18, 20 and 22) stands for 'control unit failure' requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Whirlpool front load washer wont go into rinse cycle screen flashes F 21
The F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Not quite an emergency, but it is an indication of a problem and a problem that can lead to something bigger if not looked into.The F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Not quite an emergency, but it is an indication of a problem and a problem that can lead to something bigger if not looked into.
hope this helps...
Oct 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer stops with an F-21 notice. Somehing wrong
drainage pump inside washer is broken. Most likely some debris buildup around pump. Mine just did the same thing a couple of days ago. new pump cost about $126.00
Aug 10, 2009 | Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washer wont rinse
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
Aug 04, 2008 | Maytag MAH2400A Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
59 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
