Question about Sony Ericsson Walkman W810i Cellular Phone
Camera doesnt work anymore
When i press the camera button, or if i go to camera through the main menu it flashes to the camera screen then flashes back to the main menu PLEASE HELP sony ericsson w810i
  • 2 more comments
  • szshaps Feb 20, 2008
    i tried both things, master reset and update software, but it still didnt work... PLEASE if anyone has had this problem and got it fixed let me know how to fix it, my phone isnt under warranty and it would cost 100 to send it in, and for that i can get a new phone
    ok, so is there anything i can do about it??
  • kyalian Feb 22, 2008
    I have the same problem.
    My phone worked perfectly for the first month, then as soon as the warrantly was up, camera malfunctions.
    When I turn on the camera, it seems to work for almost a second (black screen, icons, etc) but then goes back to my main screen/menu/whatever I was doing before.
    Frikken annoying is what it is.
    I've tried all of the downloads and resets (even the ones that wipe EVERYTHING) with no luck yet.
    And the cost of sending it/taking it in is not worth it.
    pee.ess. The real piss-ass thing about the whole situation is that I got this phone to replace my old Nokia, same contract (they reset the time) and same plan. My Nokia had a very nice extra warrantly on it that cost me a few bucks. If I never claim this warrantly (which I haven't/wont) then at the "end" of my first three years I get it back as a credit. So basically Rogers is holding onto my money, won't let me use my warrantly for my current phone, and won't give me my credit/money back for another year.
  • Jacko523 Mar 30, 2008
    what do you mean by change the camera settings..
    because mine has stuffed up as well and i dont even now how to get to the camera settings
Hi another solution is go to ur camra setting and chenge d "SAVE TO " setting is that Phone Memory chenge it to Memory Card.
it will work try it
Posted on Feb 22, 2008
    President:
  • 1,944 Answers
Did you try to master reset th phone? If that didn't help try to flash the software on your phone with the Sony Ericsson update service.
http://www.sonyericsson.com/cws/support/products/updateservice/w810i?cc=gb&lc=en
Posted on Feb 20, 2008
  • Damen Wong
    Damen Wong Feb 20, 2008
    If these two things don't help then most probably your camera module has malfunctioned.
Oops i put d3000 and meant to put D5000. I dropped my camera and cannot view images on screen anymore. I can look at them via the computer, so camera still works just can't view.
Do you see anything at all on the screen? For example, if you press the MENU button, do you see the menu? If you press the playback button, do you see the pictures you've already taken?
Jan 21, 2013 | Nikon D5000 Digital Camera
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
My canon 20d is playing up when i switch on my canon starts firing flash and i dont see my menu scree when pressing menu button please help
That sounds like a bad main board problem what you can do is try and upgrade your firm ware that might update and fix the problem if this doesnt work it will have to be sent off to a repair center
Oct 31, 2011 | Canon EOS 20Da Digital Camera
I have a vivitar 5022 i need to find out how the flash works how to turn it on
you have to look in the manu and turn it on auto-flash or something like that ..it actually has more than one options usually ..but ..it is in the main menu ..to do that turn the camera on ..and on the shooting mode..not on view picture mode..and it will be on the screen when you look in the menu ..select the option and press ok ..to activate ..
Mar 25, 2010 | Vivitar ViviCam 5022 Digital Camera
My camera turns on but the capture button stopped
Be sure you have fresh batteries or fully charged rechargeables. Go into the camera menu and find "reset"...follow the on-screen instructions.
Dec 31, 2009 | Samsung Digimax S630 Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Error E91:01 on DSC H7
I had this same problem. Go to Home / settings / main settings / initialize. This resets the camera and you will need to reset the date-time.
Mar 12, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
Feb 03, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony dsc-w50 flash going off before or after shutter has opened and closed
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Jan 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera / video doesnt work
First of all backup ur every important thing.Switch off ur phone hold *,3 and green call button at the same time and switch on ur phone.problem resolved.
Regards,
Sandeep Singh
Jul 28, 2007 | Sony Ericsson W550i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
238 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
