Question about Whirlpool CEM2750KQ Electric Commercial Dryer
Dont work sudenly it dont start. their is electicity ,the motor work if i test it direct
    Genius:
  • 1,122 Answers
How about the door switch?mike
Posted on Feb 05, 2010
My isuzu 4hf1 sudenly stop while giving way to another vehicle, with the gear position in neutral and idle rpm.what is the proper trouble shooting,ty
i cant understand your symptoms. but...
no year car stated or country.
the engine is direct injection engine of 4.33L capacity.
diesel injected..
do not post about other cars and all that, (giving way)
tell what you do and car did. only.
please.
your in neutral for some reason, and something happened what.?
my wild guess is engine stalled. (what trans, stick or auto?)
does not revolve,
what doesnt the starter or the engine.?
the starter motor cranks fast (huge current) and spins 300RPM
and spins the engine ,fast, and the engine starts.
the PCM (injection brain) does fueling.
I will do, cranks ok but dont start.
  1. check all fuses first.
  2. check for clean fuel filter.
  3. check for PCM errors. (diagnostic scans)
  4. Check that glow plugs work.
  5. test using TEST fuel (spray) did it start now.? or just for 3 seconds.?
if the engine fails to crank over (that mean engine crank shaft spins)
that that is a whole other, set of tests, (jumper cable starts are next)
Feb 04, 2015 | Isuzu Cars & Trucks
Dryer will not start
make sure the door switch is good. you can ck the start button by taking the back panel off of the control panel use a paper clip to put in each wire on the start switch and see if the dryer starts when you plug it back in. the door switch can be tested the same way. the only other thing would be the motor or motor switch mounted on the elect motor. good luck
Aug 11, 2010 | Roper RES7646KQ Electric Dryer
The electic fan is not turning on when it should
Did you run a hot wire direct to the motor itself? Connect it direct from the batteries positive end to the motor. If it does not work replace the motor
Jul 03, 2010 | 1987 Chevrolet Corvette
Electic seats dont work how to fix?
first check the fuses if thats not it replace your motor underneath the seat
Mar 09, 2010 | 1998 Honda Accord
My 1953 (the year 1953) Dayton 5K683 electic motor smokes when plugged in if there is any load (like like the belt connecting it to the table saw blade.) I know my father never oiled it. Does it just need...
you dont oil electric motors if it is smoking then it is burning out ,take it off and take it to amotor rewinder they can test it before starting the job but i must say that 56 years is a good run out of anything.my missus is starting to wear out and i`v only had her for 45 years .
Sep 05, 2009 | Air Tools & Compressors
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
98 elantra will not start and headlights dont work
Check that the battery connections are tight and secure. If yes, check the starter motor connectors and check current to the starter while the ignition key is turned. If there is no current, try wiring the starter directly to the battery. If it turns, then the problem is in the wiring or it could be the starter motor fuse. If the starter does not turn, remove the starter and take it to an auto parts store for testing.
Jan 20, 2009 | 1998 Hyundai Elantra
Car turns OFF
I dnt know the name of the sensor, probably its name is ignitiator, or the one directly attached to the spark plug ..............it may cost some 5000 to replace one!!
Sep 19, 2008 | 2001 Hyundai Accent
Whirlpool CEM2750KQ Electric Commercial Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
