Question about General Electric WSXH208H Front Load Washer
Wont spin or agitate. Fills, sits there through all cycles then drains. looking from top down, appears as though something is broken on the top of the drum but can't find any pieces
  • 572 Answers
Check the belt in the back.
Posted on Feb 05, 2010
Wont spin, drain or agitate
the transmission is either burnt out or the freaky looking belt that turns the pump is off. or the switch that tells the unit that the top lid is down sometimes comes loose cause some companies used a caulk like substance to keep the foot attached to the switch as slid away from where it is and the lid is not pressing that foot down to close the circuit and tell the tranny its safe to spin etc. You can fill with the lid open but not spin. There is a motor that controls all the spinning and draining or agitation and if something in their design is opening the circuit it wont perform those functions.
another idea is the timer motor isn't making contact and you might have to replace that..... there are tons of issues that can cause that.
Feb 20, 2014 | Amana Washing Machines
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer fills , sits, does not agitate, empties and spins.
I had the same problem. Take the agitator off by pulling on it extremely hard - use allen wrenches in the slots on the sides to help. This exposes the "air bell coupler" - take the 7/16" bolt out and slide it off. Chances are the spline is stripped out inside. The part is 5 bucks online
Feb 01, 2009 | GE WJRR4170E Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
It sounds like you pump is clogged. If there is something stuck in your pump the motor can't spin it to drain the water. If that is the problem then it's easy to fix. Simply clear the pump and put it back on, just make sure to clamp off the hoses to the pump with hose clamps or you will have water every where. If that is not the problem though then it means that your timer is bad and that is a little more expensive. Try the pump first though and hope that that is all it is. If not, like I said, you will need a new timer but most likely your pump is just clogged with something that is causing the pump motor to not spin. It could be a coin or a hair pin or even a sock or something. Good luck and let me know if you have any other questions.
Jan 16, 2009 | Kenmore 22422 Top Load Washer
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Kenmore 20702 Top Load Washer Problem
First check the lid switch. Its a little slot inside the top panel and when the door is closed it has a prong that pushes the switch down when closed. It is a safety feature. If you can find this press the slot with a screwdriver or something and listen for a clicking sound.It is also possible that one of the wires has come off, so that may need to be looked at too. Also check the lid to see if the prong has been broken off. If you have both of these things checking good, then it may be a more complicated issue like power to the wig wag coils, or a timer. We can however eliminate the motor, belt and water pump as these all work. I would put my money on a simple lid switch problem though.
Dec 11, 2007 | Kenmore 22422 Top Load Washer
General Electric WSXH208H Front Load Washer Logo
55 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
