Question about LG Washing Machines
WHAT COLOURED WIRES GO ON THE WATER PUMP ON A ''LG'' MODEL WF-853A WASHING MACHINE IT HAS A BLUE WIRE AND A GREY WIRE
  • LG Master
  • 3,463 Answers
It does not usually matter which wire goes on to the terminals, as they are common.
That is to say, you can connect either wire to either termoinal.
Posted on Feb 05, 2010
Testimonial: "thats great service thankyou regards Peter"
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
LG WF-T6517TC my washing machine WF-T6517TC when it start to wash get Alarm "dE" beep and stop machine. what need to do
Don't know exactly what that code is but normally washing machines will beep and switch off quickly if the pump is blocked.as it's not allowing water yo be pumped around.
I suggest that is checked firstly before calling anybody out.
Jan 02, 2015 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
My washing machine model is LG WF-660.. it cannot function due to failure indicator at water level.... it keep on "beeeping" cannot do other operation.... plz help....tq...
pl check the bp sensor or the conector of the wire harness.according to my knowledge there is no door sensor in wf-660.if bp sensor is ok change the P.C.B
Feb 03, 2011 | LG Washing Machines
LG washer Model wf-t6517te not draining water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | LG WFT1071TP Top Load Washer
LG WF T6517TC Washing Machine does not fill water
sir
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
112 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
