Question about iRobot Roomba 560 Robotic Vacuum
Same problem as voirjs 12/29/09 - runs a while & needs brushes cleaned w/same repeat scenario. have been doing all of the cleaning as felix80 said on 1/8/10; but it still continues the run awhile & need cleaning behavior. a more indepth solution is required.
I called iRobot Customer Support, and they are sending me a new cleaning head module.
Posted on Feb 05, 2010
My miele flamenco II vacuum cleaner motor makes a loud grinding noise what's wrong with the motor?
Hello Louis Casado,
Most of these motors make noise because the bearings have gone bad and need replacing...
(loss of lubricant or other-than-round ball bearings).
Alternatively... the rotor brushes have picked up something that is clashing with the housing... and needs to be resolved.
Clean it all... really good & run it without a load...
If all else fails to remedy your situation... pull the beater brush and cut everything but the fixed bristle rotor brush... clean it... cut it free... check out all clearances... and return it to service
Hope this helps!
Happy hunting!
Oct 18, 2016 | Miele Vacuums
How to clean brushes on hoover steam vac
Hi, it's Allie from Crucial Vacuum!
Cleaning the brushes on your unit is crucial in maintaining your Hoover performing at it's best and it is very easy to do. First, make sure your unit is off and unplugged, and make sure to remove the clean and dirty water tanks to avoid any possible leaking.
With the handle in the upright position, tilt the unit back and rest it on the floor. Grad the brush assembly and pull firmly until you remove them from the unit. Clean the brushes with running water until the water runs clear and the brushes are clean.
You can purchase direct your replacement items from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Aug 21, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba uh oh and two beeps
have you attempted the diagnostic test yet? i have posted a link of the diagnostic process below. I believe the test you are needing is #14 http://mysite.verizon.net/gsplews/Diagnositic-Tests_Proc.v.0.5.htm
Jun 04, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Brush cleaning, wheel thump
rchu is exactly right. No need for a complicated disassembly. If you have never pulled off those end bearings/caps, the hair may be very impacted, but removing it should solve the problem. The instructions will tell you by color (yellow for mine) which pieces come off for cleaning. Be sure to remove all such pieces. If the fit seems tight, it's probably because a lot of stuff got stuck in there. Be gentle but firm, and things the should come off will come off. Once you've cleaned all the pieces, the thumping should be gone.
Nov 14, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
83 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
