Question about GoVideo Rave-MP AMP256 (256 MB) MP3 Player
Main Memory Disappeared
I had the onboard 256MB memory pretty well fully loaded and was using a 1GB SD card, (Using firmware 2.053). From one day to the next, on turning on, it took even longer than usual to review the index. When it finally finished, it reported nothing on the player's memory. When I connect it to my computer, using WinXP Media Centre, it recognizes that removable drive is installed but trying to read the drive or transfer files to it, returns a gripe asking for media to be installed in the drive.
Any ideas on how to remedy this?
Thanks!
  • sherrijmasse Nov 13, 2008
    my rave mp3 downloads just disappeared. I don't know how to fix this. Can you help
    Problem Solver:
  • 4 Answers
As if!
What gives here? I get an email offering me assistance, from a select group of experts, but if I've solved the problem, please post it here???? Get a life!
Posted on Mar 08, 2008
My Mother board is ECS P4M900T-M2, im thinking of upgrading my video card into 512MB or 1GB video card. is it possible since the specs of my board says; Integrated Chrome9TM HC IGP Memory: Maximum up...
Yes it is possible to still plug-in an expansion video card. The 256MB limit is for the shared memory if you will be using your integrated Video Card. You can ignore it once you plug in the new video card.
Hope this helps.
Sep 04, 2011 | EliteGroup P4M900T-M (V1.0) Motherboard
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
I have a 2GB SD Memory card thats won't format and says its full
per manual... camera supports UP TO 256MB... your camera can't recognize a 2gb card.
Mar 08, 2009 | Vivitar ViviCam 3705 Digital Camera
Dc-t50 does not have menu to cancel protect on memory card
http://www.rekam.ru/drivers/dcj01x.bin
Download the firmware above... Copy it to a freshly formated by the camera SD card..  hold the up arrow for all 3 100%'s  turn the camera on it takes 2 min
Jan 24, 2009 | Gateway DC-T50 Digital Camera
SD card
I have the same camera, save the colour (black). As soon as I read your post, an alarm went off. I decided to re-check my User Guide (PDF Eng version, page16), for the Lumix DMC-FZ30:
•On this unit, you can use SD Memory Cards of the following capacity (from 8 MB to 2 GB). Please confirm the latest information on the following website:
http://panasonic.co.jp/pavc/global/cs
(This Site is English only.) • This unit supports SD Memory Cards formatted in FAT12 system and FAT16 system based on SD Memory Card Specifications. • This unit does not support MultiMediaCard for recording motion pictures. • The reading/writing speed of a MultiMediaCard is slower than an SD Memory Card. When a MultiMediaCard is used, the performance of certain features may be slightly slower than advertised. • After recording motion pictures using the MultiMediaCard, the card access indication may appear for a while, but this is not a malfunction. • Keep the Memory Card out of reach of children to prevent swallowing.
8MB, 16MB, 32MB, 64MB, 128MB, 256MB, 512MB, 1GB, 2GB (Maximum)
Oct 20, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
1GB SD memory card problem
Your camera is an old model and can't handle big memory card. Use only 128 or 256MB card in this model.
Aug 23, 2008 | Toshiba PDR-M700 Digital Camera
Need some help with DSC-W1
memory stick pro comes in 4gb, 2gb, 1gb, 512mb, and 256mb sizes. sizes up to 1gb (i.e. 256mb, 512mb, and 1gb) are what the book is referring to.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
What is the maximum amount of SD/MMC memory on e330
In my opinion there is no any limitation. I am pretty sure that you can use 1GB SD Card without any problems. Only thing that can happen is that access to your data can be a little bit slower.
Sep 11, 2005 | Toshiba e330 Pocket PC
GoVideo Rave-MP AMP256 (256 MB) MP3 Player Logo
174 people viewed this question
Top GoVideo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a GoVideo Audio Player and Recorder Expert? Answer questions, earn points and help others
