Question about Husqvarna Garden
Install Husqvarna 338XPT spur sprocket - Husqvarna Garden
    President:
  • 2,220 Answers
This is not exact but it is detailed and a very good guide, Yours is very similar.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Feb 05, 2010
Can anyone tell me the name of the nylon cog that drives the chain on the electric chainsaw
Though I've never worked on an electric saw, I would think it should be referred to either as a 'spur' sprocket or a 'rim' sprocket just like what they are called on a gas fired saw.
Mar 06, 2015 | Husqvarna Garden
Replace sprocket on rancher 460
The factory do not offer a rim sprocket for the 455/460, they are classed as semi pro saws and as such get a spur sprocket, there may be an Oregon after market one available.
Dec 29, 2012 | Husqvarna 20" 60cc Rancher Chain Saw 460
How do you replace spur sprocket on a 038ab stihl chaninsaw? how do you remove the sprocket that is over to the right of the spur sprocket?
To remove the sprocket on this saw you must remove the oiler gear that sits in the way. Remove the mounting screws for the oiler gear plate and you are home free.
I hope it helps
look for parts at a local dealer like www.arcolawn.com
joe
Feb 03, 2011 | RTO Spur Sprocket For Stihl 017, 021...
Broke tooth on chain drive sprocket. whats the easiest way to get it apart to put on new one
Standard procedure for removal of the drive sprocket on the saws i work on are
release the chain brakeremove the sprocket cover... bar & chain clean all that sawdust and oil mud with brake cleaner and or bristle brushremove circlip with a flat head screwdriver and a prying motion* find circlipremove spur or rim sprocket Replace in opposite order.. being sure to align the chain speed driven oil pump with the notch in spur sprocket if equipped(some arborist saws require a piston stop to remove the clutch before you can remove the spur) BUY A STIH AND TALK TO YOUR DEALER.. THEY ARE FULL OF INFO AND VERY HELFUL
Jan 12, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
My chainsaw starts when there is no bar and chain on it but when I put the bar chain and side casing back on tighten the chain and pull the starter cord it is hard to pull and then the chain goes loose...
Have you just replaced the chain?
If so there is a possibility the chain and drive sprocket don't match causing the engaging spurs to ride on the sprocket teeth
Jun 24, 2010 | Husqvarna Chain Saw 20" Bar
Changing clutch drum on a husqvarna 455e rancher chainsaw
You have a couple of options. Oregon offers both rim and spur sprockets to fit your saw. Rim systems are initially more expensive but replacing just the rim portion is less expensive than 2 spur sprockets.
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
A part number for an OE spur sprocket and illustrations that may be helpful for disassembly may be found here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
Your saw has an outboard clutch, this is a very guide for removal:
More questions or if I can be of more assistance please reply below. Good Luck. HTH
Lou
Feb 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
221 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
