Question about HP Pavilion dv5-1125nr Notebook
My broadband's modem cannot be used at my laptop but can be use at another laptop.
    Scholar:
  • 51 Answers
The modem - and the wireless cards if it's wireless - should come with a software to ensure the system will recognize your internet connection. If your modem is supposed to be wireless, just try and see if your laptop would work with an Ethernet wired connection to test if the modem itself would work with that laptop. If not, then your laptop may have a missing or corrupt component caused by malware. It also depends on the models of your two different laptops. Maybe the one that doesn't pick up the modem is incompatible with the given software. In which case if your machine is clean of malware, then you should contact your ISP and sort out the possible incompatibility issue. Good luck. Please do rate me if any of my ideas work. Thanks
Posted on Feb 05, 2010
I am using samsung 3g metro gt-s5350 with MTNL sim. I am unable to connect to internet with my laptop using this mobile as modem. ... 8:
you need to know service that your provider for sim service. sometimes, you need to change your sim card type to broadband and get the credit or top up for that broadband. In other case, sometimes they provide us with mobile internet. For this, you can browse internet using mobile only, but can browse using pc.
if you came from malaysia then i can help you because im from malaysia and know how to connect using mobile as modem for pc/laptop. Is easy and cheap. No need to buy broadband. As long your mobile phone have 3G.
May 25, 2011 | Samsung Modem Configuration Software...
Hi sir, i got a problem regarding the celcom broadband. the problem was happen since yesterday. i left my notebook for along time (may be about 20 hours) where i am not to turn off the celcom...
Power off the broadband modem and your laptop, wait 30 secs then power up the broadband modem until the modem has restarted, then boot up the laptop.
If you still have problems, leave me a comment with a description of what happened plus the error messages.
Jan 31, 2011 | Computers & Internet
How do i connect it to the net? Do i still require an external modem for my broadband connection?
Every broadband connection requires an external modem. Your laptop might be shipped with an internal modem. But that is for dialup purposes. Today broadband uses a technology called ADSL. So you require a modem to decode the signals.
Jun 28, 2009 | HP Compaq nx6310 Notebook
I cannot connect to by bsnl broadband modem with laptop
Please check your DNS settings. If you dont know your DNS settings you shall use the global DNS server 4.2.2.2
Jun 04, 2009 | Computers & Internet
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
Usb broadband modem
Im not aware of any gadgets, but you can always use the USB stick on one laptop, share the internet connection, and connect the other laptop throught the shared connection.
That would require your laptops to be networked, either by a crossed cat cable or with regular switching or routing.
Feb 02, 2009 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
My Wireless internet card don't work
i think you are a little confused, your laptop may have a wireless card internally, but you need a wireless broadband or cable router for the wireless adapter to pick up a signal.
A fax modem cannot be wireless and cannot be broadband as you cannot fax using a broadband connection.
Assuming you have a broadband connection you will need a wireless modem/ router or roter connected to a broadband modem, not a standard 56k dialup modem as they aren't wireless or broadband.
Nov 08, 2007 | Toshiba Satellite A60 Notebook
HP Pavilion dv5-1125nr Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
