Question about Microsoft Xbox 360 Console
No picture on tv
Loss of video to the tv. have tried switching inputs on tv as well as hooking up component cable vs. yellow video cable.
  • 340 Answers
This is a graphics processor unit fault,(gpu) the console needs stripping down and new heatsink paste applying to the gpu, this is basically the same fix as rrod, so there are plenty of guides on this site or youtube if you feel like tackling this yourself, or book a pro repair center.
Remember thumbs up if this helps.
Posted on Feb 05, 2010
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
I hooked up the cords exactly as picture and when in dvd input the picture is in black and white. I tried movie the yellow video chord to every single hole on the back of my tv and it doesnt go to color??...
If you tried the yellow composite cable "in every single hole" it wasn't exactly 'exactly' following the manual then, was it?
Are you using component cabels, too (red, green and blue). Mis-wiring them will give you B/W or other wierd visuals.
Your TV's inputs and what is selected by the TV's controls would determine which cables' input it display. You could prove whether the composite is the culprit by removing it while viewing the TV. If the picture goes away, THAT cable is carrying the video you're watching. Otherwise, maybe you need to select the component input and check the conenction of each wire while watching.
Mar 18, 2011 | Bose 3·2·1 II System
The wires from the wii to hook into my samsung t.v. do not match is there an alternative wire configuration that I might be able to obtain?
The cables that come with the Wii are composite video cables with the standard red, yellow and white cables. You might be trying to plug them into the component video input, which has red, blue, and green.
Check your TV to see if you have any red, yellow, white inputs. Use that input if you are using the cables that same with the console.
Alternatively, you can buy component video cables for the Wii. This will be for the red, blue and green input. This will provide you with higher definition (480p vs. 480i) and a slightly sharper picture.
Good luck.
Nov 29, 2009 | Nintendo Wii Console
Our dlp tv shows great color when watching tv but when we watch a dvd the red is brown and the pink is tan? HELP
if you already check your cables.. and it's still the same.. the problem is probably the VIDEO BOARD
here is a picture of what is a video board..
Nov 28, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
I spent the last hour on the phone with tech support for my local cable company. after the duration, we came to the conclusion that there was in fact, not a space for the red, yellow and white chords....
Without seeing anything, the yellow=video, the red and white=audio. The yellow/video "output" of the cable box goes to the yellow/video "input" of the TV. The red and white are the audio that go from audio "output" of the cable box to the audio "input"of the TV. I don't know what the Cable company was telling you???? The cables are "RCA" and give you the worst clarity for a picture. If you cable box has three output ports colored Red, Green, and Blue ("Component') and you TV has the same three as inputs, that will make your picture much better. If you can hook it up with the component jacks, you will still need the audio RCA (red and white) between the two units. I hope this helps.
Oct 27, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
NO volume
often people make the mistake of hooking their devices to the tv using more than one input.  a cable box for example may have many different types of outputs but you are only going to use one to the tv (preferrably the highest quality connection). try switching the inputs on the tv to see if you get the same picture on two different inputs.   If using s-video, you will also need a red & white RCA cable for audio.  The order of video cable quality from lowest to highest is this: Coax(screw on), Composite(yellow,red,white), S-video(Round)+(red,white), Component(video=red,green,blue), HDMI(carries HD video & sound)
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
"No Sync Signal" on both component inputs
Component ports can and do fail. You can get a replacement board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2017 | Hitachi 50V720 Television
No Picture, Only sound
You need to tell the PS3 that you are now using the new video method. It is still trying to output video on the yellow cable, not the component. If you go to settings>video and tell it to use component, and then switch the cables real quick, it should work.
An easier solution is to do a backup from the system menu, then a "restore" (quick restore is fine), and then power it off, hook up the new cable, and it will detect the video method when it turns on for the "first" time (since the restore).
You do have component input on your TV, and that is the input you are on when you are trying this, yes?
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
