Question about Invicta Subaqua Noma Iii S
How do i remove links from my subaqua noma111
  • 2,334 Answers
Check out my TIPS here and you will find out how to do that
Posted on Feb 05, 2010
Watch ******** my invicta 5511 has snapped how do i get a new one
you can find what you need at Invicta Web-site http://invictawatch.com I had order straps from them for my Sabaqua NOMA III and russan diver here is also the link for the service http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Nov 16, 2012 | Invicta Subaqua Noma Iii S
What powers my subaqua noma iii gmt limited edition model # foo27
It has an automatic movement powered by the movement of your arm.
Nov 07, 2010 | Invicta Subaqua Noma Iii S
How do you remove the links from an invicta subaqua venom stainless bracelet?
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Jun 10, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
How do you remove links from the subaqua venom
Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
Apr 25, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
SUBAQUA NOMA 3 SCREWS LOOSEN AND THE BRACELET OPENS ANYBODY ELSE
What 3 screws? Give me: Make, model, all the numbers on case back. Explain in detail what 's wrong. Where screws are/were located and so on.
Feb 05, 2010 | Invicta Subaqua Noma Iii S
Removing links
Watches either have screws in the links that you can remove to remove a link. Or they have a pin in each link that you must push out to remove a link. Some have a "hairpin" looking keeper that you remove. Hope one of these will work for you. Good Luck
Dec 14, 2009 | Invicta Subaqua Noma Iii S
Invicta Subaqua Noma Iii S Logo
484 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
