Question about Indesit 24 in. IDL500 Built-In Dishwasher
I have an indesit idl 535 dishwasher . lights 1 and 2 rapidly flash and it is full of water. The dishwasher does not work and these error lights keep coming on now. Can you assist ? thanks Butchuk1@hotmail.com
5 Suggested Answers
SOURCE: Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Posted on Apr 13, 2008
SOURCE: Dishwaher not working
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Posted on Feb 08, 2009
joe_lishman
  • 192 Answers
SOURCE: ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Posted on Jan 22, 2010
SOURCE: Indesit idl 535 dishwasher not heating up,I have
Hi,did you find out what was wrong with your dishwasher,as i have the same problem.steve
Posted on Mar 14, 2010
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
Ndesit IDL 535 DW, not cycling, water coming from under unt.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
When i start my dishwasher it sounds like it is filling normally then error lights 1 &3 (3h&9h) flash rapidly and water begins to drain away
This indicates an error with the pressure switch and indicates that it is jammed on full. First try switching off ther AC power to the washer and letting it stand for 30 minutes. Then switch back on the AC power and see if the error is still present. If it is then the pressure switch will need to be replaced. The pressure switch is how the machine determines how much water there is in the machine and if the switch is indicating the machine is full it will automatically pump and empty as soon as new water enters the machine.
Nov 10, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL500 Built-In Dishwasher Logo
573 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Level 1 Expert
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
