Question about Olympus WS-321M Digital Voice Recorder
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
    New Friend:
Yeh....the reason he asked the question was that he deleted the files using his computer.......we can't go back in time to do it the right way. What we need now is how to fix the problem.....I also deleted my recordings using my macintosh by accident. For some reason my recorder says that my "memory is full" despite my recorder being EMPTY (no files). How can I FIX it?
Posted on May 20, 2011
  • 207 Answers
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Posted on Feb 07, 2010
SOURCE:
How to restore audio files from formated Olympus digital recorder
You should stop recording new ones to prevent the old ones from being overwritten. If your digital recorder has a memory card, take it out and insert it to your computer with a card reader. If the device has built-in memory, just connect it to your PC directly. On your computer, you need a video/audio recovery program. Fine one, install and run it. The software will help you scan lost audio files from your recorder, then it'll show you what it's found. Choose the files you want and hit the "Recover" button to start recovery process.
If you're a Mac user, please feel free to try this Mac based video/audio recovery app. http://www.leawo.org/photo-recovery-mac/
May 16, 2016 | Olympus DS-40 Digital Voice Recorder
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
I just deleted (remotely from my mac) all the files in Folder A of my Olympus DS -40, b/c I'd gotten a memory full message. Even though it shows no files in Folder A, it still says memory full.
I found the answer on this site: http://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1126#22 I held down the menu button--got to the sub menu and restored it to the original default setting. It cleared everything and now I can record tons again. Note for future--don't delete on your mac--only delete the files on your dvr to save you the trouble of having to do this.
Nov 25, 2009 | Olympus Audio Players & Recorders
Need to recover deleted file from recorder
Sorry for a late reply but chances are high to recover your deleted files.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
May 22, 2009 | Olympus VN-3100PC Digital Voice Recorder
Olympus ds-30 deleted file recovery
Nov 26, 2008 | Olympus DS-30 Digital Voice Recorder
Problem with memory/erasing discrepancy
I did erase all from the device main menue after having copied them to my computer, that cleared the remaining files and recovered part of the memory. Then I did reformat from the same menu and recovered the entire memory! ;)
Oct 20, 2008 | Sony Network Walkman NW-A3000 MP3 Player
"Memory Full" message flashes, even though all files are deleted
Use the reformat option in the menu to completely erase the memory.
Oct 15, 2008 | Olympus DS-2300 Digital Voice Recorder
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Olympus WS-321M  Digital Voice Recorder Logo
325 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
