Question about Pro RX65 Radar Detector
My belltronics rx65 pro series doesn't go through initial start up test and volume always starts out completely turned down. Why
I have samsung galaxy I. my phone was turned off and when i turn it on it doesn't start as it stucks on samsung and doesn't start up. i took off the battery off and on but it still not working
hi,
try to hard reset your phone first by doing this procedure...
To Hard Reset Samsung I9000 Galaxy S
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If YES is selected, all data including third-party applications will be deleted from your Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
if you do the above procedure and nothings happen ,its time now to re-flash your phone to its original version and a certified mobile technician will do that for you...thanks for trusting fixya
Oct 01, 2012 | Samsung Galaxy S GTI9000 Smartphone
15.4-inch macbook pro A1286 turn on but wont start
  1. Verify startup process passes initial memory checks and POST (Power On Self-Test) with no beeping sounds or flashing sleep LED. Check video activity.
  2. Disconnect any peripherals and Ethernet cable.
  3. Reset SMC using the procedure for your computer.
  4. Reset PRAM by holding down Command-Option-P-R keys while restarting, until you hear the startup sound for the second time.
  5. Start up from known-good original system media or an up-to-date, bootable Mac OS X volume.
  6. Run Disk Utility or check Mac Resource Inspector (MRI) results to verify SMART status of the your hard drive.
Jul 31, 2012 | Apple Computers & Internet
Vector 940 works for a moment, then flashes ?L03 CAL ?MARKERS
just turn off the sws messages.
it probably recieved a jumbled signal from a "roadworks traffic control unit".that it couldn't understand.
Aug 31, 2009 | Pro RX65 Radar Detector
Display shows "H 14.4 V". Doesn't appear to work.
I'm pretty sure that this is caused by a failed internal capacitor, and that this probably was caused by a sudden voltage spike while starting your car. You will have to send your RX65 to Bel/Escort for repair. While they are at it, they will also upgrade your RX65's firmware to whatever their latest firmware version is, even though the firmware version displayed on your RX65 won't be different when you get it back. Also, I always power my RDs on after I have started my car. This avoids the possibility of sudden voltage spikes damaging my RDs.
Mar 25, 2009 | Pro RX65 Radar Detector
No display
Have you tried doing a factory reset of the firmware as described in the user manual? To do this, first power off your RX65 using its power button. Then hold down the two buttons which are used to enter Program Mode and, while holding down these two buttons, press the Power button again. Release all three buttons when the word "Reset" is displayed on the LED display. Obviously, if the display doesn't light up, then either the display itself is defective or one of its display leads has a cold solder joint.
If your RX65 is in warranty and you can make a photocopy of your sales receipt, then Bel will repair it at no charge. You will have to pay the shipping cost to Bel.
Mar 23, 2009 | Pro RX65 Radar Detector
Problem to turn on my RX65
Obviously you have pressed the power button on your RX65 in order to try to power it up since you mention that the green light on the SmartCord comes on. Here is one possible solution, which resolves any stored user settings which might have become corrupted due to power fluctuations:
First, press the power button so that the radar detector is turned off (green light is off). Then hold down the two buttons used for programming and, while holding these programming buttons down, press the power button. Release all three buttons once you see "RESET" displayed on the RX65's display. Your RX65 has now restored all factory default settings from a separate area of programmed memory, and this (hopefully) will restore your RX65 to proper operation.
Jan 12, 2009 | Pro RX65 Radar Detector
No audio
Hi everyone,
Bel/Escort now uses a special and proprietary "high temp" speaker which resolves issues of speakers blowing due to high ambient temperatures or heat which builds up within the speaker when it is alerting for extended periods of time. If your RX65 is in warranty and you can make a photocopy of your sales receipt, then great! All you have to pay is shipping to Bel. Bell will replace the speaker with the new version, flash your RX65 with whatever the latest firmware is, and calibrate and test your RX65 too. So, all of this is peachy if your RX65 is under warranty.
If your RX65 is out-of-warranty or if it doesn't have a serial number or was bought from a non-authorized dealer, then the service charge as I recall is $80. Thats not bad since your RD will come back working like brand new.
A note about the speakers: They are made by PUI, but the speakers are proprietary to Bel/Escort. Thus you can not buy them from any source -- not even direct from PUI.
Dec 15, 2008 | Pro RX65 Radar Detector
Service needed
The internal self-calibration procedure has repeatedly failed, causing your RX65 to display the Service Required message. You need to send it to Bel for repair.
Dec 13, 2008 | Pro RX65 Radar Detector
Bel RX65 not working properly
Regarding the problem of the unit turning on for a second, then turning off after you plug it in....
Plug it in and hold the power button down for 5 seconds. This resets the unit. The unit will still turn off after this however. After that, push the power button on again for one second and it should remain on. Good Luck!
Jan 12, 2008 | Pro RX65 Radar Detector
Beltronics pro rx65
false laser alerts when sun is low..
Nov 06, 2007 | Pro RX65 Radar Detector
Pro RX65 Radar Detector Logo
44 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
