Question about Dell PowerEdge 6400 Server
I have a dell poweredge 6400/700 I have 2 scsi hard drive install I WOULD LIKE TO SETup the server to install windows 2003 when i start the server I get a error no boot device avalaible.What can I do
  • oss_123 Feb 05, 2010
    no I don't have the driver
  • 583 Answers
You will need the Dell installation disks to install the appropriate drivers and configure your SCSI controller to recognize the new drives. Do you have the Dell Server utilities and drivers discs?
Posted on Feb 05, 2010
  • Mark Tidwell
    Mark Tidwell Feb 05, 2010
    Go to the Dell website www.dell.com. On the server, there should be an service tag. You'll need this to get the specific drivers for your server. At the top of the page, click on Support, on the support page, click on Small Business Start Here button. Click on the download drivers button, click on the Enter a Tag button and enter your service tag. You'll then be able to access all of the drivers specifically for your server.
  • Mark Tidwell
    When your server powers up, does it not go through a SCSI utility load up before it comes to the no boot disk error? You should get a brief prompt to hit a key sequence to enter into the SCSI configuration mode.
  • 2,567 Answers
The drivers for this server model could be downloaded from here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PWE_PNT_P3T_6400&os=WNET&osl=en&catid=&impid=
The following link also explains how to install & configure the SCSI drives:
http://support.dell.com/support/edocs/systems/pe6400/en/ug/scsi.htm
Posted on Feb 07, 2010
  • 4,281 Answers
First when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd/dvd rom .
Also make sure that your harddrive is reocognized in bios.
Then save settings and exit from bios.
If your harddrive is not recognized then reattach both connection to harddrive.
Then insert disk into cd/dvd rom then it boot with that disk.
Then follow the procedure and install win20003 .
Let me know if you need further assistance.
Thanks for using FixYa.
  • Dell Master
  • 1,183 Answers
Hi
if you are getting the message no boot device found.The following could be the reasons for the same.
Faulty diskette, diskette/tape drive subsystem, hard-disk drive, hard-disk drive subsystem, or no boot disk in drive A
If the problem persists, replace the system board.
One work around you may try is disbale the floppy disk drive in BIOS and then check.
For more help you can check the following link
http://support.dell.com/support/edocs/systems/pe6400/en/it/messages.htm
Thanks for using Fixya
proton
    Novelist:
  • 153 Answers
I'm assuming that you have successfully installed the Windows 2003 Operating System. Try to make sure, that if you have 2 Hard drive installed, you should check that the Boot configuration will load the primary HDD that you have-it should be first in the list. Configure the boot configuration. Try to check if the jumper settings are correct for the Primary HDD and the Secondary HDD. We don't know, the motherboard might be loading the Secondary instead of the Primary where the OS is installed.
Regards,
sl4x
please vote if this solved your problem
  • Dell Master
  • 17,093 Answers
Here is the book on the machine .Sounds like you are going to be replacing hardware:
http://support.dell.com/support/edocs/systems/pe6400/en/sm/beep.htm
How can I find the Windows Server 2008 driver files for the Adaptec CERC SATA1.5/6ch?
OK, EZPZ.
These drivers will install when you first start installing windows 2008 server. You'll see a option that says: Hit F4 for any further drivers needed for windows to install. I think it's F4. You can place these drivers on a thumb drive OR a CD - you must extract the files on to a thumb drive. At the very start of the windows install you'll see the option for additional drivers.
First screen - Success
SCSI - Yes, that is correct. Correct, but This isn't a SCSI controller
If you choose the SCSI driver from Dell, on the disk, you won't get...
This screen. This screen means that windows could not find any driver for your drive and there for, you must start over - Same steps.
But make sure you choose the correct driver - you might have to try a few that are in the list.
Greatest of luck - EZPZ
Have a great night..
Aug 11, 2014 | Dell PowerEdge SC1420 Dual Xeon 3.2GHz 2GB...
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
I have a dell power edge t300 server. i need to install windows 2003 server. i dont have dell cd for windows 2003 server. while installing the hard disks (scsi) are not detected and setup aborts. how can...
If your Dell server cam with the Windows Server 2003 software, you should be able to order a replacement cd. Go to http://www.dell.com/support If the software was not packaged with the server, you will have to buy it at http://www.microsoft.com/sales
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 23, 2011 | Dell PowerEdge T300 Server
I have dell 4600 pe serveri want to install Server2003 os i have configured raid 1 on the machine every thing is fine but! on boot process it display message no Boot Device Found Press F1 to continue F2...
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Jul 01, 2010 | Dell PowerEdge 4600 Server
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
Problem
This server direct not boot by windows cd....
and u any time install window u lose the all data....because they have scsi hard drive and configuring bydefault Raid 5 ......so plz make backup before u start this prosiger.......Dell providing u lots of cd's check it this cd "installation and server management" bootable cd put this cd into your cd rom drive...and i am giving u link that how to complete install window in this server.
http://rapidshare.com/files/175988908/how_to_install__os_-_window_storage.doc.html
Sep 18, 2008 | Dell 2.8 GHz Second Processor for...
I want to format scsi drives and configure raid0
You can either do this in the BIOS or (easier) just run a Linux installer (such as Ubuntu) and it will offer to do it for you when it sees Windows-formatted partitions.
Jan 06, 2008 | Dell PowerEdge 2600 Server
Dell PowerEdge 6400 Server Logo
224 people viewed this question
Alun Cox
