Question about Brother HL-2040 Laser Printer
Makes click a clack noise and toner cartridge wont come out!
Click a clack... Quite loud. Toner cartridge wont come out. I did manage to get it out by dismantling the printer. Put it back in and same problem. The cover for the toner wont open either. The small arm on the left seems stuck. When I took apart the side of the printer the arm seems to go to a circular guide and had come off... Looks to be that it pulls something out of the cartridge when the cover is opened. That is the area of the clanking sound when I try to print... Time to just toss it out? Already tried a new toner cartridge.
  • ebathke Jun 28, 2008
    Same problem, clacking sound, front door will not open, due to jamming of left connector.
  • aleelya Oct 06, 2008
    Just installed a new toner cartridge. Paper kept getting jammed. Printed again and the loudest clacking noise started. The print job worked but now I can open the toner door/drawer.
Toss it.
These are 'disposable' printers. You can get a new one for less money than it would cost to fix.
Posted on Mar 28, 2008
SOURCE:
Printer makes a loud clicking noise and the screen suggest that the toner recovery cartridge needed to be replaced
Replace the waste toner box. clicking noise could also be the toner bottle being turned by the toner bottle motor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 23, 2015 | Konica Minolta bizhub Office Equipment &...
Wont accept a new toner cartridge makes a very
you have to cleaan all the gears. on the side and use a bit of oil.
this is a commen problem form sf 5100
May 17, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Having a clicking noise problem when installing a new toner cartridge into the fax machine. Reusing the old cartridge makes the noise go away. There is nothing wrong with the new toner (we have 2 and both...
You state that you have 2 new toners and both make a noise, but the old one does not. If both the two new toners came from the same source then it is possible that the vendor has a quality control problem and manufactured several defective cartridges. It does happen. If these are not genuine Muratec toners, that makes it all the more likely because often they are remanufactured and attention was not paid to details. Is the old cartridge from the same vendor and does it bear the same brand name if it is not a genuine Muratec item? 15 years in this business tells me that if the old one is quiet and the new ones are noisy, something is wrong with the cartridges, not your machine.
May 05, 2011 | Muratec F320 Plain Paper LED Fax
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
LOUD GRINDING NOISE
The black dust is toner. Be carful as it is carcenagenic (dont get it on your skin) you will need to dispose of the leaking toner cartridge and get a new one. also you will need to clean the printer very carfully to get rid of the spilt toner. A combination of spray duster and a toner hoover are the best way. do not use a normal hoover as you will kill it.
It is always possible that you have done serious damage to the printer using a non standard toner cartridge. I would recomend getting a qualified person to give the printer a good service.
Jun 03, 2009 | Sharp AL-1655CS Laser Printer
I think its a problem with the cyan (blue) toner...when i print a colour document the printer works but makes a very stranhge (high-ish pitch) noise and the colour which should come out green comes out a...
The Cyan toner cartridge is jammed, it needs to be taken out and try and move the white plastic gear round a bit to free it. It normally is very stiff and wont move much, but if you can move it a fraction that will do. One thing, did you overfill the cartridge with toner? sometimes that will cause them to seize up.
Delboy
Jan 25, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Samsung 3160fn all in one printer. making loud clicking noise when printing
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
May 05, 2008 | Samsung CLP 300 Laser Printer
Loud clicking noise
Power the machine on with drum and toner removed, check for noise....
It will be either the Fuser, Toner or the drum.
If it is non gen. or refill toner, fault found.
The drum is a normal consumable that you change every 3 to 4 toner cartridges, so if any of you have used more than 4 toners and havent changed the drum, I'd say that we have found your problem.
......now to the hangers on .....
Fuser, thats the hot bit at the back, these have a gear that cracks because the whole fuser assemble is old, brittle and stiff, you can pull it all apart and change the gear and be off, but soon it will more than likely break again, I know cause if I do that as the fix they come back within 6mnts.
Replace fuser, or have it replaced
f9d929d.jpg LINK to P/n and price
the gear that breaks/cracks
9b32a46.jpg LINK to gear info
Fuser is a HiVolt, HiTemp part. Caution!!!!
Nov 16, 2007 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
147 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
