Question about Gigabyte GA-8KNXP Motherboard
Memory DDR DDR Memory problems recently started - stoped running in duel memory. Computer shops claim I need to replace Motherboard. System has multiple hard drives with 3gig ram. Would really appreciate all any advice.
  • oz_bob Feb 20, 2008
    Not as yet. Thanks for suggestion. Will read manual and apply suggestion. Thanks Bob
  • 97 Answers
Have you checked the memory settings in the bios check the manual how to do this
Posted on Feb 20, 2008
I have a MS-7101 motherboard with a Pentium 4 Dual Core CPU based system . RAM is 512 MB (DDR) . However , sometime after I have switched on the P.C. , the screen (display) suddenly starts going bad ....
Most of the distorted display related to video memory. MS-7101 Motherboard coming with embedded video controller so your system memory is sharing space for the video memory. Replace and check your system RAM or check RAM module with Memtest , if it is showing error u should replace memory module.
May 10, 2011 | Intel Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
RAM Help!
Hi there.
Yes it is related to PC2 and it runs at 800Mhz, this why your system is seeing only half the speed, your system does however support a module running at 333 module and a 400 module, this is the base limit that the memory runs at.
If the memory was 533 then the computer would not start up because the bios wouldn't recognize it.
Thanks for using FixYa!!
Apr 22, 2009 | EliteGroup P4M800-M7 Motherboard
I WANT TO INCREASE RAM ON MY COMPUTER
SORRY BUT I INPUT AN INCORRECT MOTHERBOARD IN ERROR.THANK YOU FOR YOUR SUPPORT.
Feb 19, 2009 | Intel Motherboard
Go to belarc.com and run the program. It will tell you everything you need to know about your computer and then some!
Feb 19, 2009 | Generic Memory Computers & Internet
Adding a second 1GB pc3200 DDR ram!
Are you sure memory is same (type and make) as they can have different timings and speeds.
remove 2nd memory module see if computer starts if it does i believe memory module could be faulty
Jul 23, 2008 | Asrock M266A Motherboard
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
Memory Issues
PC2700 (DDR333) memory and PC3200 (DDR400) are backward-compatible with PC2100. Memory is designed to be backward-compatible, so generally speaking, you can safely add faster memory to a computer that was designed to run slower memory. However, your system will operate at the speed of the slowest module or system component (the "lowest common denominator" effect). One thing to keep in mind is that the memory does need to be the same type-for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. Let me know if you have any questions. Good Luck, Tim
Mar 01, 2007 | ASUS P4GE-MX Motherboard
Gigabyte GA-8KNXP Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
