Question about HP DeskJet 845c Printer
How to reset the blinking ink indicator of hp 845c
rey17
  • 66 Answers
SOURCE: HP Deskjet Color 845C Printer - Black Cartridge Problem
hi,
try to clean the nozzle with clean cotton w/ alcohol i think your cartridge has getting clog..or maybe it's getting empty!
rey
Posted on Nov 03, 2008
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
  • 43 Answers
SOURCE: printer
hello ! please check if the catridges is seated well .may be the sensor have not detected the catridges ., so as to reset the printers memory .
good luck
Posted on Jul 08, 2009
pineworks
  • 4041 Answers
SOURCE: how to reset my MP160
Hi there this will reset the inks for you.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
mishrajk21
  • 202 Answers
SOURCE: I have an older printer a hp deskjet 845c series.
pls first tell u hv clean then install the cairtage if so then pls check if u open the door cairtage comes mid position if so then problem due to inkif it doesn't so then this problem due to logic bord / caridge block it should be cross check by replacing one by one
Posted on Jul 17, 2010
Printer indicator keep on blinking even with ink
Open printer door, remove cartridges one at a time to see if that clears the error. Also power cycle the printer to see if the blinking changes.
Mar 01, 2011 | HP DeskJet 845c Printer
All the lights on my hp 845c are flashing all at once and i can't print anything
that's indicate error code with ink cartridge, open upper cover ink cartridge must in the meddle, if so remove power replace the ink and clean encoder strip by wiping clean cloth. check also that ink docking / refilling station not yet full.
Mar 29, 2010 | HP DeskJet 845c Printer
My hp deskjet 845c won't print pink. I've tried two different ink cartridges and no pink ink. Is my printer probably on it's last leg? I have also tried cleaning the print heads...didn't help.
Are you using HP factory new cartridges?
If you are using third party or worse, refilled cartridges, that may well be the cause of your proiblems.
Don
Feb 24, 2010 | HP DeskJet 845c Printer
Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
Printer
good luck
Jul 08, 2009 | HP DeskJet 845c Printer
It was suggested that I buy a new printer cartridge for my HP Deskjet 845c rather than use a refill, which causes the cartridge light to blink. I did go out and buy new cartridges for both color and black...
i dont know if anyone has logged this, but i would think that logically the lights would continue to blink until it detects the right amount of ink density and If they are chipped that the chip registers correctly. Ttry installing just one of the cartridges ( the cheaper one)
Jun 23, 2009 | HP DeskJet 845c Printer
Hp Deskjet 845c printer's cartridge light blinks constantly.
It probably has, the printer might not detect your cartridges properly, try using new ones
Jun 22, 2009 | HP DeskJet 845c Printer
hi,
rey
Nov 02, 2008 | HP DeskJet 845c Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
HP DeskJet 845c Printer Logo
928 people viewed this question
Seeker5211
Seeker5211
