Question about Acer Computers & Internet
My comcast internet wont work on my acer laptop
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
Ok, here's my problem. I had comcast, comcast got turned off, we turned it back on, and they came over and gave us a new modem. Now our router wont work with the new modem. Everything works, other than the...
> fast answer
Turn the router off.
Disconnect the electrical power from the router.
Reconnect the electrical power.
Turn the router on.
It should immediately "reboot" itself, and "talk" to your Comcast modem, and connect to the Internet.
Feb 12, 2011 | Computers & Internet
Online light flashing at times, no internet. Occasional message: failed on loadingskin name comcast; the file shell.css is required in your sscommon/skin/comcast/css directory.
failed on loading skin name "comcast". the file "shell.css is required in your "sscommon/skins/comcast/css/" directory" this is what i am getting from my acer desk top.... comcast is my internet service provider and say "everything is fine on their end" but i cant access the net... please help me
Jun 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Having problems setting up the dynamic comcast cable.router puts out a signal but laptops do not communicate.can not use my internet on main computer cable modum icon shows 100 mbps but explorer wont bring...
Call COMCAST. They can trouble-shoot from "their" end,
if you tell them that none of your computers get an IP-address.
Also, plug _one_ computer _directly_ into the COMCAST modem.
Can you web-surf with that configuration?
Jul 17, 2009 | EnGenius ESR-1221 EXT Router
My acer laptop keyboard isn't working!
my acer 5515 laptop keyboard wont work
Jul 02, 2009 | Computers & Internet
ACER wireless internet
open up internet explorer and click on tools ,internet options,connections, lan settings, then check connect automaticly.That warranty I imagine is so you are covered out of the states
Feb 11, 2009 | Acer Aspire 5100 Notebook
My internet won't work on my new laptop.
First turn off you laptop. Second, go to your comcast cable modem unplug it from the wall and wait about 3mins. Now plug the comcast modem back it and wait for all the lights to come back (will take about 2-3mins). Now plug the yellow ethernet cable into your laptop if its not already and turn your laptop on. You should now have internet.
Also if you using a Comcast Surf Board modem be mindful of the standby button on top of the modem. You can tell your in standby mode if the standby light (bottom light) is amber. If it is press the standby button once to get out of standby mode.
hope that helps
May 12, 2008 | Computers & Internet
D-link dir625
When your laptop is working, check the ip address.
Open your DOS PROMPT, type iconfig then click enter. If your ip address on the laptop is 192.168.x.x, that means that you are getting your internet from the router. If your ip address is (just an example:68.x.x.x, that means that the router is not functioning properly.
If the laptop ip is 68.x.x.x(just an example), make sure that your comcast modem is connected to the INTERNET PORT of your router.
You just bought your router so the best way to deal with this problem is call Dlink tech support so they can walk you thru the router configuration.
Good Day
Mar 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
