Question about Loewe Aconda ACO9383 38" TV
My Loewe TV is starting up and shutting off repeatedly.
Please check Q674, Q663 and Q562 for dry solder joints.
VERY common problem.
Posted on Apr 27, 2010
  • Loewe Master
  • 12,061 Answers
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is, it starting up, detecting a fault condition and shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Feb 05, 2010
Loewe tv power
Hi, the original remote that comes with your tv is the correct remote for you. because you have it connected to the sonos-playbar you will now need to use the Sonos remote to control the volume. The Loewe remote will not work for the volume anymore. Sorry.
Oct 18, 2013 | Logitech Televison & Video
My tv has been shutting itself off and attempting to turn itself back on after about three seconds. This repeats like some kind of loop over and over again continuously failing to give me any visible...
What you are describing is a high voltage problem, the horizontal output transistor is probably shorted, this is a job for a technician that requires a specif part and soldering to address the issue.
Jan 09, 2011 | Loewe ART636 36" TV
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
I have sound but no picture with my Loewe TV
Bad Ballast Board Call Encompass Parts 1-800-638-3328
Apr 13, 2009 | Loewe Articos 55 55" Rear Projection...
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
Loewe Articos 55 RP
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
Apr 24, 2008 | Loewe Articos 55 55" Rear Projection...
Service for loewe TV
Loewe is not importing into the US, however, they still contract with Panurgy (based in NJ) to provide service to US owners. Call them at 1-866-563-9387, and they can advise on what to do, or provide an in-home service call to repair using original parts.
Apr 06, 2008 | Loewe ARC332 32" TV
TV turns off after aboiut 2 hours of uninterrupted play
There is a software patch availabe to increase the thermal cut off temperature. Can only be programmed using the Loewe Cablemax kit. Another solution is that the fans at the back all blow into the tv, reverse one of these fans, this gives a flow through the cavity. Remember to remove the filter from the one you reverse.
Dec 30, 2007 | Loewe Articos 55 55" Rear Projection...
Red light is always on
Power supply problem, Loewe issued a PSKIT for these items. part number 90415.900. If none of the secondary fuses are gone kit required (All parts should be fitted)
Oct 27, 2007 | Loewe Aconda ACO9303 30" TV
Televison & Video Logo
758 people viewed this question
Top Loewe Televison & Video Experts
Computer Repairing
Computer Repairing
Jerry Umali
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
