Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Jetclean eq plus dishes still dirty and soap door is open and most of the soap is still in there thanks
  • 129 Answers
Screens , chopper ,and spinner arm stopped up take apart and clean
Posted on Feb 05, 2010
2 Suggested Answers
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
Maytag jetclean dishwasher eq plus
The best dishwasher soap we have found is Finish Quantum and they have good rinse aid too
Jan 24, 2014 | Dishwashers
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Dish soap is not dissolving
First try a different brand of soap. Check that the soap door has opened about half way through the wash cycle. You may need a water softener.
May 13, 2010 | Maytag 24 in. MD5600 Jetclean II Built-in...
Hi, I'm having trouble with my maytag jetclean eq. I've removed everything down to what I think is the drain impeller and can't figure out how to remove what seems to be this last piece. Fwiw, the trouble...
the problem is not your dishwasher but your water actually. hard water is the reason for the cloudiness. www.dishwasherfilter.com makes a filter just for this problem. it fits right under the sink and is guaranteed to work. it is very affordable and you will be amazed how your dishes come out after the very first load.
Jun 14, 2009 | Dishwashers
Soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Soap residue on all items after dishwasher completes its cycle.
Hi Rioski
The first thing to do is where you put the jetdry turn it down to one. use powdered detergent the best is electosol is the blue box,dont use the heated dry feature and run the hot water at the sink first to get it good and hot that should fix the problem. I also recomend using GLISTEN every 6 months. its a citric acid that is designed to clean the dishwasher. i hope this helped.
brent
Oct 01, 2008 | Dishwashers
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
907 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
