How do you find the screen that will allow one to adjust color..
  • 12,061 Answers
Depending on the screen, somewhere, there are some buttons, usually 3, & usually one pushes a button and then, when a menu comes up you navigate with a button between the options.
Posted on Feb 05, 2010
I have a creative live cam and it has a blue line in the middle of the screen
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu.
Feb 01, 2013 | Creative Labs Live! Cam Voice Webcam
The colors doesn't look will, it look pale
You should always include brand name and model number when asking for help since the menu can be drastically different between sets.
Most later TVs give you the adjustments via the setup screens and most all contain adjustment points that allow you to change color depth, focus (soft or sharp) and brightness.Not knowing anything about your set, you will have find the menu for these on your own.
Jan 09, 2012 | Televison & Video
Convergence
Have you tried to adjust the convergence in service mode yet?
If not here are the steps.
1) Turn the TV off with the System off (under flap of remote)
2) Press: Display, 5, Volume+, then Power. If successful, service text will appear on the screen.
3) Use 2 & 5 - to select the PJE category. Be careful, like your computer, you don't want to be adjusting the wrong screen.
4) Press 9 - to get to the convergence adjusting.
5) Press 6 several times to get the convergence screen of choice. (I like the grid)
6) Use the remotes arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color(Push it sideways or up and down and hold). Press 3 to change color to adjust(red, green or blue). When done, press center of joystick again, this will turn it back to white.
Note: Try to keep the grid even and square.
7) Repeat step 6 for all parts of the screen that need it.
8) Once done, you need to save your settings. Press: Mute,Enter. Then on the T.V. press "Flash Focus" (it will set it self)
9) Turn off Power.
Jan 10, 2010 | Sony KP-51WS510 51" Rear Projection...
Green tint in the color on my big screen tv
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 12, 2017 | Samsung Televison & Video
I just bought Sony Bravia flat screen television set today. The images on the screen are 90% greenish in color. How do I set it right to the right human color ? Please help ASAP or I will return the TV set...
go into menu, look for picture or setup mode. in setup look for chroma/color & tint/tone controls. you should be able to adjust to personal preferences. one other setting, is the color temp setting. this will allow you to change to warmer back wash. hope this helps because the Bravia is a good set
Sep 14, 2009 | Sony BRAVIA KDL52XBR2 Television
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Hi, I'm trying to work with a HTML editor creating pages on a web site. When I click on text colors & background colors I get a picture of a square filled with a bunch of smaller box which I assume show me...
He is correct, But you can make the adjustment yourself. Go to the Windows front end screen and RIGHT click, select Properties then the Settings tab. Check that the monitor displayed is the one you are using and then use the controls offered to make adjustments. Be ready to click the cancel button offered in case the screen becomes unreadable. The system will allow you about 30 seconds to confirm any changes you make. If you do not confirm then the screen will revert to the state it was in before you made the changes. This is to ensure that if you are not able to read the screen then it will be put back as it was originally.
Dec 01, 2008 | Computers & Internet
Cant locate or adjust the the TV color
All the controls should be accesed thru the on screen menu,your remote should have a menu or display button and if you press it on the screen of the tv you should see a list of different options ,I am not familiar with the kind of menu that your set has but I know the color adjustment should be in the same screen that allows you to change the brightness,shapness,tint,color and contrast,the more you use the menu and become familiar with it the easiest it will be to use.Let us know if you need more information.
Nov 06, 2006 | Sony KV-32S26 32" TV
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
