Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My hard drive was making a clicking noise and now is not being recognized on my pc?? Is it repairable or operable? How?
  • 12,061 Answers
That "Clicking" sound" is the death rattle of a drive, sorry, I have experienced this many many times. Generally they cannot be easily fixed. One can try to get an exactly the same drive and remove the Motherboard off a Brand New drive, and replace the MB, on the "Faulty" drive, if the board is your problem, You must be prepared to "Blow up" that new board too. If sucessful, then usually it will, "just work" as it was before. If it is the drives "internals" There isn't much more one can do. If however the data is imperitive, there are places, that for a price, will recover the data 100% guarranteed.
Posted on Feb 05, 2010
3 Suggested Answers
fslahmed
  • 127 Answers
SOURCE: I/O Magic 320GB external hard drive making clicking noise
it happens when the hard is gone bad or can`t be recognised.you can try uninstalling the drive from device manager.you can check the hard drive case or can try the hard drive on some other computer.
Posted on Jul 08, 2009
paper bag
  • 72 Answers
SOURCE: Dropped Seagate 1.5 TB hard drive. Makes a noise
Probably not. A hard drive is very delicate and if dropped the lasers could have broken or even the discs.
Posted on Dec 26, 2009
Externel harddrive will not open on computer and keeps making a beeping noise
If your USB drive is not being recognized by your computer when you plug it in
try unplugging it, and also unplugging any other USB devices that are connected.
All USB devices, even those that have an external power supply, draw a portion of their power directly from the USB bus.
If you have too many devices connected to the same USB controller, problems such as a drive not being recognized can result.
Incompatible File System
The Mac-operating system can read drives formatted under the FAT32 and NTFS file systems used by Windows, but Windows will not recognize HFS, the file system used by Mac OS.
If you connect an HFS-formatted external drive to a computer running Windows, the drive will spin up but Windows will not respond.
The drive will have to be used with a Mac, or reformatted using a disk-partitioning utility.
Drive Disconnected from Power
Some external hard drives have the option of drawing all their power from the USB bus, or receiving supplemental power from a wall outlet.
If your drive will not operate using power from the USB bus only, connect the power supply. Many drives do not have this option; they will not operate unless they are connected to both a power outlet and a USB port.
Driver Update Required
Some older motherboards may require updated USB drivers to properly utilize a modern USB 2.0 device.
If you have exhausted all the basic troubleshooting steps above, visit the website of your motherboard's manufacturer and look for updated USB drivers.
Also, ensure that your Windows installation is fully up to date.
Corrupted Files
USB hard drives are susceptible to data corruption if either the power or USB cables are disconnected during a write operation.
Over time, this could lead to a situation in which Windows will be unable to write to the drive correctly.
To have Windows attempt to fix corrupted files, run Scandisk by right-clicking on the drive after double-clicking on "My Computer." Click Properties > Tools > Error Checking. Click the two check boxes to have Windows attempt to fix errors and bad sectors.
Click "OK" to start the operation.
Depending on the size of your hard drive and the speed of your computer, this operation can take a few hours to complete.
Failing Hardware
If your drive is still not being recognized, but it is making audible noises when it is plugged in, the drive may be failing.
Nearly every hard drive manufacturer distributes a free utility to check the drives that they make for errors.
Visit the manufacturer's website to download this utility.
If the drive is failing, the utility will most likely be able to detect it.
Contact the manufacturer for a replacement if the drive is under warranty.
Oct 01, 2012 | Computers & Internet
Computer does not recognize external hard drive, western dig 320 g. It has been making clicking noises before it started this problem.
Clicking noises are not an issue, as the hard drive uses voice coil technology, which clicks. Plug into another USB drive.
Jan 22, 2011 | Western Digital My Book Essential Edition...
My external hard drive continuously beeps and makes a clicking noise. Also, no computer is able to recognize this external hard drive.
The spinning mechanism on the HDD is failing meaning it can't read data of the platans. Unfortunately you need to buy a new one as this one can't be repaired.
Dec 29, 2010 | Hitachi Computers & Internet
My Western Digital 500GB EDD has been making Clicking noise
Here are some options to try: - Purchase an alternate enclosure for your hard disk enclosure in case the circuit board in the WD case has gone bad. - Try accessing the drive via MS DOS window and use CHKDSK command to repair the drive (if you can get it to be recognized). - Try connecting the drive to an alternate PC or even a Mac to see if the drive can be recognized (perform disk repair if recognized).
Feb 10, 2010 | Western Digital My Book Essential Edition...
Drive making clicking noises and not recognized by computer
A clicking noise from a hard drive is a sign of a faulty hard drive.
That is why the computer does not see it.
The hard drive needs to be replaced.
Oct 08, 2009 | Beyond Micro (BM200MD3U28M) 500 GB USB 2.0...
Jul 08, 2009 | Computers & Internet
Can't be recognized.
If the noise is like a repetitive ticking or clicking. Well, the sorry to say that the hard drive had crashed... which makes the noise... And sorry to tell you that you cannot do anything but to buy another...
sorry... Fixya!!!
May 21, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
My Arc Disk 20 is suddenly no longer recognized by my computer and is making a clicking noise. I assume that it is failing but the light is still on. How can I recover info from that drive!
Clicking noise means hard drive physical damage. When that happens the data inside hard drive is lost.
If data is very important it can be sent to a recovery facility with a clean room 100, that is a special room where hard disk can be opened. The repair is over $600, and does not guarantee success.
Unless the data inside is really important, data inside hard disk (when clicking) is considered beyond recovery.
Jan 03, 2009 | Archos ARCDisk 20GB 4200rpm 480Mbps USB...
External Hard Drive Crash
sure...take it to a data recovery specialist(the repair network may have something to that effect)
Jun 16, 2008 | Western Digital 500GB My Book World...
External USB drive making clicking noise - Windows does not recognize it!
it is going to crash soon as the platter seems to broken it is non repairable yes but u can save the data by taking help of any good tech
May 19, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
450 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
