Question about Sharp AR-M160 Laser Printer
U 2 error on my Sharp AR M160 copier
I changed the toner on my Sharp AR M160 and now the display is flashing a U then 2. I have had the machine for about five years this is not the first time I've changed it.
  • 417 Answers
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Posted on Feb 20, 2008
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Hi when i turn the machine on it flashes ch
The "CH" in sharp stand for open door or cartridge not install, check that you close the door in the right order, first front then right door, check that you have the toner cartridge installed.
Dec 02, 2010 | Sharp AR-M160 Laser Printer
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
AR-M160 Black and White Copier: it flashes H then 2 will not copy...
H2 means termistor damaged enter code 14 .if not solved change termistor
May 17, 2010 | Sharp AR-M160 Black and White Copier
I CHANGE THE CARTRIDGE OF THE COPIER AND TURN ON IT. SO THE COPIER DISPLAY MESSAGE 2F.
i think the error your actually getting is F2. this error pertains to toner cartridge chip error. it's that little chip on at the end of the cartridge.you'll need to have that replaced.
Mar 25, 2009 | Sharp AR-M160 Laser Printer
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Changing toner getting U2 40 code
The cartridge is faulty, in most cases not a genuine cartridge. If the copier works with the old one that means the "new" cartridge in defective.
If you brought a original Sharp cartridge you should return that and ask for a new one.
Jul 25, 2008 | Sharp AR-M160 Laser Printer
Ch error
Some of the covers of the machine might be open.
Regards,
Cäppärs
Jul 17, 2008 | Sharp AR-M160 Laser Printer
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp AR-M160 Laser Printer Logo
306 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
