Question about Mitsubishi WS-65819 TV
Where is the reset button on the ws 65819 mitsubishi medallion
SOURCE: Mitsubishi WS-65819 Sender Board problem
yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Posted on Mar 26, 2008
rsheehan
  • 69 Answers
SOURCE: My Mitsubishi ws-65819 won't power up. When I use
Unplug it ,leave it unplugged for at least an hour.
now slowly plug back in , if you notice a small spark coming
from the plug when you plug it in that's normal
which means most likely the regulator or output tran is out.
is about 150.00 200.00 normal cost. no more.
If the plug doesn't spark at all when you plug it in slowly
could be a Fuse :>
Posted on Jun 28, 2009
SOURCE: My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Posted on Jan 25, 2010
welcomejee
  • 10594 Answers
SOURCE: by Dario Dominguez on nov
There are two convergence ICs located behind big aluminum heat sink in center board of tv if you see tv from its rear side (in fact both ICs are attached with this aluminum heat sink), replace these ICs to fix your tv problem.
Below image shows exploded view of tv chassis and convergence ICs location is marked with red line for better idea.
IC number is STK392-570 and tv requires two ICs, soldering work is required to replace both ICs from circuit board.
You can buy STK392-570 from HERE for $25 each
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Nov 23, 2010
dduncan774
  • 760 Answers
SOURCE: Have a Mitsubishi WS-65819 (about
You lost your convergence IC's and possibly a resister or two that are in the same circuit. If you are good at Soldering, this should be somewhat of an easy fix. I believe you can still get the IC's for this set.
Posted on Aug 09, 2011
Testimonial: "Thank you very much - I'll check that out tonight!!"
My medallion Mitsubishi TV goes from color to green and blue. What can I do to fix it. My model # is WS-65819
CRT base card circuit fault. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Nov 01, 2016 | Mitsubishi WS-65819 TV
Mitsubishi Medallion WS-65819 wont turn on. Code 2-2
The power supply regulator section circuit inside should be troubleshooted.
Mar 28, 2013 | Mitsubishi WS-65819 TV
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD?
yes......you can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
I have a 63 inch projection tv, 8 years old, that stopped turning on last week. Not sure what's wrong with it. You can hear the power turn on inside the television though the screen does not turn on. No...
LOOKING AT THE AGE OF THE TV IT MIGHT HAVE DRY JOINTS ON PCB,S SO IF U KNOW ABOUT ELECTRONICS AND GOT SOLDERING IRON RESOLDER SUSPECTED SOLDER JOINTS AND THEN TRY.
Aug 12, 2010 | Mitsubishi Televison & Video
My t.v. wont turn on. I have a Mitsubishi, Medallion HD 1080. Model ws-65819.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
Jan 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsbishi model ws-65819 HD 1080 medallion, wont turn on
Mitsubishi WS-65819 TV Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
