Question about Jenn-Air JJW8230D Electric Double Oven
BULB REPLACEMENT - Jenn-Air JJW8230D Electric Double Oven
  • 254 Answers
That is just an 40w appliance bulb theres probably 10 diifferent manufactures that make this bulb and want allot for them u can find one at a local lighting store, or local appliance store,, this is a common bulb, to get to it u must remove the glass cover that covers the bulb. it should screw on to the receptacle.. hope this helps
Posted on Feb 05, 2010
The light in my oven is out. How do I get the light out to replace?
Does it have a cover or is it just a screw-in bulb? Some have a cover with two or more screws that have to be removed to get to the bulb. Some just have a recessed fixture with a safety wire catch to keep the bulb from moving. For these you carefully remove the holding wire, and then unscrew the bulb. It is easier if you consult your user manual and have a replacement bulb ready.
Jan 01, 2018 | Ovens
How do you replace oven light ?
First, acquire a replacement bulb, Then, remove the one that is not working. Then install the replacement bulb in the oven. That ought to do it.
Mar 15, 2016 | Ovens
Replacement light for ""J b968s" ge oven
Remove the lamp and determine what type it is. Take it to a retail store that stocks replacement appliance lamps or an appliance parts supplier and purchase a replacement. Install the replacement lamp.
Dec 01, 2013 | Ovens
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
Viking professional oven bulb. how do i replace it? how do i get the glass cover off? it wiggles but does not turn.
The glass cover pulls off from each side, push to one side while pulling down. The bulb has two prongs that pull straight out. Now only to find a replacement bulb. 120 volt 28 watt
Oct 23, 2010 | Ovens
How do I change the light bulb?
Normally the glass cover turns anti clockwise until it comes off ,you can then access the bulb. Remember to use a high temperature replacement.
Dec 25, 2009 | Baumatic Ovens
How to replace oven light
most oven light covers simply unscrew or unclip remove old bulb however with certain models you might need to get in touch with the manufacturer for a replacement bulb but most can be obtained from the high street
Jul 08, 2009 | Ovens
Delonghi microvave replacement bulb, microwave only 6 months old
I got a Delongi Mic form argos too ,model ED8525S-SBD, sounds like a similar problem to what happened to it last year. Issue is that the bulb explodes (mainly due to the very strong spring on the door I think) leaving filament lieing on the metal chassis, hence the trip switch in your fuse box trips.
Didn't manage to find a replacement bulb but at least if you remove the old bits then it will get the machine back up and running and stop the trip tripping!
Take off the top by removing the 4or 5 screws around the outer edge at the back. The bulb sits directly behind the front panel inside its own metal chassis. There is a diamond shaped black plastic flange which the 2 power wires feed onto. 2 metal lugs hold this inside the chassis. straighten the lugs and the bulb holder pulls out. Even with the bulb removed I think there was a blown fuse and I had a further issue with the turntable not turning(this feeds off the same circuit as the bulb). So maybe Argos were right - the machine only cost £80 at the end of the day!
Jan 31, 2009 | DeLonghi Ovens
Replacement bulb
there are more than one type of bulb for these ovens, the most important thing is that you get one that is rated to withstand temperature of 300oC, or they will shatter with the heat.
Plz rate my solution.
Thanks.
Dec 08, 2008 | Neff U1421 Double circotherm Electric Oven
Jenn-Air JJW8230D Electric Double Oven Logo
205 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
