Question about Coleman Powermate 27 Gallon Air Compressor
Burnt up the compression ring and would like to replace it with l
Burnt up the compression ring and would like to know if i can fix it with something like leather
  • 494 Answers
Years ago a felt hat was used to make repairs, little strips were cut off and inserted behind the rings.
Posted on Feb 14, 2010
How do you know when vehicle has jumped time, or blew headgasket?
have a compression test done to check compression pressures and ring condition
over heated engines leave the rings soft/broken and not sealing on the cylinder walls
it will be rare if the valve timing changed from over heating==more likely a burnt valve
Apr 29, 2016 | Oldsmobile Bravada Cars & Trucks
How to fix my honda civic it has low compression and week fire how u fix it
low compression can be either leaking head gasket-bad head /burnt valves--piston rings --damaged cylinder wall all of these are a tear apart fix a rebuild depending on mileage and condition of engine a replacement engine might be a better financial solution ---as for weak spark coil --wires-spark plug -fouled spark plug --and if same cylinder as damaged one the compression
Sep 30, 2015 | Honda Cars & Trucks
Why won't it start?
Hi, Donna your compression is too low either from extremely worn rings or bent or burnt valve you need at least 80 lbs. Good luck and have a nice day.
Bad motor 60 PSI Compression Yamaha R6 Forum YZF R6 Forums
Example of low compression scooter won start
Fix Low Compression and or Engine Noise for less 10 00
Jul 11, 2015 | Motorcycles
How do i fix the compression on my 50cc kymco agility
If it is a 2 cycle, I'm not familiar with kymco, the only way to fix the compression is to replace the piston rings and/or piston. It is not uncommon to burn a hole in a piston if the carberator is gummed up. If it is a 4 cycle (probably isn't) you could have a burnt, warped, or sticking valve. Either one it requires taking the head off for further evaluation.
Oct 21, 2014 | 2011 Kymco Agility 50
What to do when there no psi on cyl 4 to get the psi up agan"?"
There are at least three possible reasons for no psi in cyl No 4.
1. Burnt or damaged exhaust valve in that cylinder
FIX Remove head and replace faulty valve
2. Blown head gasket (water mixed with sump oil shows milky on dipstick and steam or water coming out of exhaust tailpipe, radiator water disappears )
FIX Remove head, grind flat and assemble with new gasket.
3. Broken piston rings, or cracked piston or burnt hole in piston.
FIX replace faulty parts.
Squirt some sump oil ( 2 or 3 spoonfuls ) through spark plug hole,
spin motor , and if compression PSI improves then it is rings or piston, if no PSI then it is faulty ex valve !!!
Jun 26, 2014 | 2003 Mitsubishi Lancer
No compression in cylinder 2 mk 4 golf gti
If you are sure the compression is low on that one cylinder (might want to get a second opinion) the most likely problem is a burnt valve.
That will require taking the head off and having it "rebuilt". $$$
Second most common problem is something wrong with your piston rings. That wil require an engine overhaul. $$$$$$
Here's how to tell before you tear the engine down.
With your compression gauge handy, get an oli can with some motor oil ready. You'll need about 1.8 cup or six tablespoons full.
Check the compression without the oil, write it down.
Add or squirt the oil in the cylinder, and check the compression again.
If the compression comes up with the oil added, the problem is the rings on the piston. If the compression stays the same, it is a burnt valve.
There is a small chance it could be a leaking head gasket.
Jan 19, 2013 | Cars & Trucks
My mazda has no conpussion how can i fix that i
no/loss of compression can be from a few different problems blown piston/piston rings[fix rebuild engine and replace piston parts ]camshaft flattened lobe [replace camshaft]valves burnt/bent carbon build up [remove head and repair/replace valves ] valve springs weak/broken[repair or replace ] head itself cracked [replace ]these are some of the reasons that u can loose compression if ur guy did compression test and determined its the head[valves ] then replace head if car is worth fixing then fix it good luck
May 31, 2010 | 1990 Mazda MX-6
I have 1200 bandit with fuel getting into oil
Check the Compression in all 4 cylinders, if the compression is low on one cylinder, squirt some oil or or WD40 down the bore and immediately recheck the compression. If the pressure goes up a fair bit you have a broken ring, if not you could have a burnt valve. If your getting fuel in the oil it definately sounds like a ring problem
Nov 08, 2009 | 1997 Suzuki GSF 1200 Bandit S
I have a 1997 Subaru Legacy Outback AWD. The
when you replaced the plugs , was one of them (cylinder 1 ) dirty and fouled ?
I'm thinking that bad rings in cylinder would give you low compression , and eventualy cause the missfire by fouling up the plug.
There is an inexpensive product that will help with the compression by filling up scratches in the cylinder walls. It is called Restore , and it is one of the only products of its type that I have used , and feel actually works.
Unfortunately , if your rings are broken , or badly worn , nothing in a bottle will fix them.
If your car had a distributor cap and rotor , I would change them too.
May 13, 2009 | 1997 Subaru Outback
Samsung 42" rear projector 1080i
I have the same TV with the same problem. This model have a defective chip, the chip just burnt out. It burnt out on me a bout 2 years ago and it just burnt out on me again last month. It cost me $300 to replace it both times. This model sucks, I will never buy a another Samsung.
Jan 07, 2008 | Samsung PCH521R 52" Rear Projection...
Coleman Powermate 27 Gallon Air Compressor Logo
88 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
