JVC LT-32E488 picuture almost solid white - Televison & Video
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
Lcd tv has sound but no picture, checked the inverter board and light is coming on the screen but no image
1. Symptom: Powers up, relay clicks, LED turns green, backlight comes on but there's no display from any input, and no OSD.
Solution: On the T-Con board labeled 320WTC2LV3.7, stickered J01420PE7F0288, check/replace:
F1 = 2A, 35V SMD (measured 9 Megaohms in circuit) - OK!
Dec 27, 2013 | JVC LT-32E488 32 in. LCD Television
JVC LT 32E488
Unless this JUST started happening AND the TV worked previously, or you recently added a device to your set up, I am guessing that you simply are on the wrong input. For instance, I have a playstation connected to Video 2 and if my TV is set to Video 2 input AND my playstation is NOT on, the screen will be lit, but no picture. Make sure you are on the correct input.
Oct 26, 2013 | Televison & Video
Tv turns on but has no sound
I'm going to have to say un-mute it and make sure audio is set to TV speakers if you do not have a receiver .
Oct 15, 2013 | JVC LT-32E488 32 in. LCD Television
JVC LT-24HD32J TV SCREEN GOES BLANK AFTER 10 SECONDS WITH JUST THE SELECTED CHANNEL DISPLAYED.
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | JVC LT-32E488 32 in. LCD Television
Is there anyway to fix a cracked flat screen
If it is out of warranty it will cost as much, if not more than a new tv to replace it.
Aug 29, 2010 | JVC LT-32E488 32 in. LCD Television
JVC LCD have sound no picture model LT-32E488
it can be either the backlight inverter board or the power supply module is not supply 24vdc to the inverter board.
Oct 31, 2009 | JVC LT-32E488 32 in. LCD Television
I have the same problem with my tv.
take back off lie flat
where the hd leads go into that board remove the screws at the top and bottom as its one long unit top to bottom
unscrew metal shield as well
remove all cables from board 2 ribbons are locked and require clipping down then ribbon removes
flip board over remove metal can to expose board notice 2 TSOP chips at top look att the pins one should look dull and not shiny
to fix i used heatgun a quick blast on pins sorted problem out
mask off board and chip around with metal etc... to not damage board.
Aug 24, 2009 | JVC LT-32E488 32 in. LCD Television
Et powers on, has jvc logo, has sound but no picture
Backlight is defective.
I suggest placing it on Ebay and using profits to get a new TV.
Backlight replacement is possible, but the bulbs are unavailable so it would be required to purchase similar model from ebay to get them. There are other methods but this is the easiest.
Jul 26, 2009 | JVC LT-32E488 32 in. LCD Television
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
