Question about HP Officejet 6310 All-In-One InkJet Printer
I want to learn how to sccan
I want to learn how to scan
    Sergeant:
    Champion:
  • 265 Answers
Read the instructions, if you don't have them go www.hp.com
Posted on Feb 05, 2010
2005 Chevy Malibu Lt v6 3.5, has anti theftwont go off, after ignition cylinder change
Did you change key also ? does it have transponder chip in the head of the key ? Needs to be programmed . You change what ? Ignition lock cylinder an key ?
Important: When replacing either the vehicle keys, PCM, or TDM and the 10-Minute Relearn Procedure is used, ensure that the appropriate calibration is selected for the replacement component on the calibration selection screen of the service programming system. The appropriate calibrations for specific vehicle theft deterrent (VTD) system components are described below.
• When preparing a TDM for replacement, the Prepare Module For TDM Setup Procedure calibration is required. This allows the retrieval of required information from the TDM prior to its replacement.
• When learning vehicle keys and the 10-Minute Relearn Procedure is used, the Vehicle Theft Deterrent Learn For Learning Replacement Keys calibration is required. This clears all previously learned keys from the TDM and enables the TDM to learn new vehicle keys. For learning additional vehicle keys, refer to Adding Keys .
• When replacing a TDM or ECM and the 10-Minute Relearn Procedure is used, the VTD Learn for Powertrain calibration is required. This clears the previously learned fuel continue password in the ECM and enables the ECM to learn the fuel continue password of the new TDM.
Important: When replacing a TDM with a GM SPO Replacement Part, insure the Setup a New TDM procedure is performed prior to the 10-Minute Relearn Procedure.
Connect a scan tool to the vehicle.
Turn ON the ignition, with the engine OFF.
Ensure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info. under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on the component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a master vehicle key, turn ON the ignition, with the engine OFF.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10-Minute Relearn Procedure.
Jun 13, 2017 | Cars & Trucks
Cannot get my 2009 colorado into program mode to set tps sensor
What engine ? Are you talking about Throttle Learn ? Did you replace throttle body ?
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. The learned airflow values are stored within the ECM. These values are learned to adjust for production variation and will continuously learn during the life of the vehicle to compensate for reduced airflow due to coking. Anytime the throttle body airflow rate changes, for example due to cleaning or replacing, the values must be relearned.
A vehicle that had a heavily coked throttle body that has been cleaned or replaced may take several drive cycles to learn out the coking. To accelerate the process, the scan tool has the ability to reset all learned values back to zero. A new ECM will also have values set to zero.
The idle may be unstable or a DTC may set if the learned values do not match the actual airflow.
Throttle Learn
With Scan Tool-Reset
Ignition ON, engine OFF. With a scan tool, perform the Idle Learn Reset in Module Setup.
Start the engine, monitor the TB Idle Airflow Compensation parameter. The TB Idle Airflow Compensation parameter value should equal 0 percent and the engine should be idling at a normal idle speed.
? If the engine is not idling normally, proceed with the Learn portion of the diagnostic.
Clear the DTCs and return to the diagnostic that referred you here.
May 16, 2017 | Cars & Trucks
Why won't the car start with the new Crank shaft position sensor installed? 2005 Buick Lacrosse cxl 3.8l engine.
After replacing crank sensor Perform the crankshaft position system variation learn procedure. Refer to Crankshaft Position System Variation Learn !
No you don't need to replace the balancer !
Install a scan tool.
Monitor the powertrain control module (PCM) for DTCs with a scan tool. If other DTCs are set, except DTC P0315, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
Select the crankshaft position variation learn procedure with a scan tool.
The scan tool instructs you to perform the following:
4.1. Accelerate to wide open throttle (WOT).
4.2. Release the throttle when fuel cut-off occurs.
4.3. Observe the fuel cut-off specifications for the applicable engine.
4.4. The engine should not accelerate beyond the calibrated RPM value.
4.5. Release the throttle immediately if the value is exceeded.
4.6. Block the drive wheels.
4.7. Set the parking brake.
4.8. DO NOT apply the brake pedal.
4.9. Cycle the ignition from OFF to ON.
4.10. Apply and hold the brake pedal.
4.11. Start and idle the engine.
4.12. Turn the A/C OFF.
4.13. The vehicle must remain in Park or Neutral.
4.14. The scan tool monitors certain component signals to determine if all the conditions are met to continue with the procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool monitors the following components:
• Crankshaft position (CKP) sensors activity--If there is a CKP sensor condition, refer to the applicable DTC.
• Camshaft position (CMP) signal activity--If there is a CMP signal condition, refer to the applicable DTC.
• Engine coolant temperature (ECT)--If the engine coolant temperature is not warm enough, idle the engine until the engine coolant temperature reaches the correct temperature.
Enable the crankshaft position system variation learn procedure with the scan tool and perform the following:
Important: While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is returned to the operator and the engine responds to throttle position after the learn procedure is complete.
5.1. Accelerate to WOT.
5.2. Release when fuel cut-off occurs.
5.3. Test in progress.
The scan tool displays Learn Status: Learned this ignition. If the scan tool indicates that DTC P0315 ran and passed, the CKP variation learn procedure is complete. If the scan tool indicates DTC P0315 failed or did not run, refer to DTC P0315. If any other DTCs set, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
Turn OFF the ignition for 30 seconds after the learn procedure is completed successfully.
The CKP system variation learn procedure is also required when the following service procedures have been performed, regardless of whether DTC P0315 is set.
• Engine replacement
Feb 07, 2017 | 2005 Buick LaCrosse
P0315 hammer h3 2006
code p 0315 refers to crankshaft position system---variation not learned ===causes engine mechanical fault ---wiring
check for correct air gap from the sensor to the rotor and check for wiring and connections
Dec 26, 2016 | Cars & Trucks
How do I replace the crankshaft sensor on my 2001 Buick Regal? Both knocksensors?
You best bet is take to a ASE certified repair shop or a GM dealer ! When replacing crank sensor a special procedure has to be done with a scan tool .
The Crankshaft Position System Variation Learn Procedure should be performed if any of the following conditions are true:
DTC P1336 is set
The PCM has been replaced
The engine has been replaced
The crankshaft has been replaced
The crankshaft harmonic balancer has been replaced
The crankshaft position sensor has been replaced
Important: Set the vehicle parking brake and block the drive wheels when performing the crankshaft position system variation learn procedure in order to prevent personal injury. Release the throttle when the engine reaches the SECOND fuel cut off. Leaving the throttle open during the fuel cut-off will allow the engine to decel at an even rate. Once the learn procedure is completed, the PCM will return the engine control to the operator and the engine will respond to the throttle position.
Important: The scan tool crankshaft position system variation learn function will be inhibited if engine coolant temperature is less than 70?°C (158?°F). Allow the engine to warm to at least 70?°C (158?°F) before attempting the crankshaft position system variation learn procedure.
The scan tool crankshaft position system variation learn function will be inhibited if any powertrain DTCs other than DTC P1336 are set before or during the crankshaft position system variation learn procedure. Diagnose and repair any DTCs if set.
The crankshaft position system variation learn function will be inhibited if the PCM detects a malfunction involving the camshaft position signal circuit, the 3X reference circuit, or the 18X reference circuit.
If the scan tool indicates a problem with the cam signal, refer to DTC P0341 .
If the scan tool indicates a problem with the 3X crank signal, refer to DTC P1374 .
If the scan tool indicates a problem with the 18X crank signal, refer to DTC P0336 .
Now why do you want to replace these thing's ? mite be able to save you some time an money. Do you have a check engine light lit ? Codes ? Does it start an run ?
Dec 08, 2015 | Buick Cars & Trucks
When car is running and i remove dipstick,it sounds like the oil is boiling or gurgling
Check your PCV valve and system as it may not be properly ventilating creating preasure in the crankcase also have vehicle sccanned and report the codes for further advise
Sep 29, 2012 | 2001 Chevrolet Cavalier
2007 aveo misfire faults
gm has a problem with this from way back. double check your spark plugs and if they are not ac delcos, change them. ive seen this time and time again swearing, myself, that there is no way that the plugs would cause this issue. it always comes up with random misfire and usually another 1 or 2 codes misfire codes. put in ac delco, no more codes. let me know
Feb 22, 2010 | 2007 Chevrolet Aveo 5 Hatchback
I have an all-in-one deskjet F2400 and i cant figure out how to scan pics into my computer
just insert picture ur picture then open "hp solution center" installed in ur pc then now a window will appear clck on scan pictures. clck on "picture to file" then clck on scan then click on ok... ur pics will be scanned
Dec 01, 2009 | HP DeskJet F380 All-In-One Printer
How do i change the crank positioning sensor on a 8.1 liter chevy silvarado?
Crankshaft Position Sensor: Service and Repair
Crankshaft Position (CKP) Sensor Replacement
REMOVAL PROCEDURE
IMPORTANT: Care must be taken when removing the crankshaft position (CKP) sensor. Use penetrating oil and allow to soak around the CKP
sensor before removing the sensor. Twist the sensor to break the O-ring seals loose. When removing the sensor, pull the sensor straight out of the
engine block at the same angle the sensor was installed. Failure to be careful may result in sensor damage.
1. Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
2. Disconnect the crankshaft position (CKP) sensor harness connector at the CKP sensor.
3. Remove the fuel line bracket and retaining bolt.
4. Use penetrating oil and allow to soak around the CKP sensor before removing the sensor.
5. Remove the CKP sensor retaining bolt.
6. Prior to removal of the CKP sensor, rotate the sensor back and forth.
7. Remove the CKP sensor at the same angle at which the CKP sensor was installed.
INSTALLATION PROCEDURE
IMPORTANT: Inspect the CKP sensor O-ring for wear or damage. If a problem is found, replace the O-ring. Lubricate the new O-ring with engine
oil before installing.
1. Install the CKP sensor at the same angle at which the CKP sensor was removed.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the CKP sensor retaining bolt.
Tighten
Tighten the bolt to 12 N.m (106 lb in).
3. Connect the CKP sensor harness connector.
4. Install the fuel line bracket and retaining bolt.
5. Lower the vehicle.
6. Perform the CKP System Variation Learn Procedure. See: Testing and Inspection/Programming and Relearning
IMPORTANT: For additional diagnostic information, refer to DTC P1336.
1. Install a scan tool.
2. With a scan tool, monitor the powertrain control module for DTCs. If other DTCs are set, except DTC P1336, refer to Diagnostic Trouble Code
(DTC) List for the applicable DTC that set.
3. Close the vehicle's hood.
4. With a scan tool, select the crankshaft position variation learn procedure.
5. Observe the fuel cut-off for the engine that you are performing the learn procedure on.
6. The scan tool instructs you to perform the following:
^ Apply the vehicles parking brake.
^ Block the drive wheels.
^ Cycle the ignition from OFF to ON.
^ Apply and hold the brake pedal.
^ Start and idle the engine.
^ Turn OFF the A/C.
^ Place the vehicle's transmission in Park (A/T) or Neutral (M/T).
^ The scan tool monitors certain component signals to determine if all the conditions are met to continue with the procedure. The scan tool only
- Crankshaft position (CKP) sensors activity - If there is a CKP sensor condition, refer to DTC P0335 or DTC P0336.
- Camshaft position (CMP) sensor activity- If there is a CMP sensor condition, refer to DTC P0341, DTC P0342 or DTC P0343.
- Engine coolant temperature (ECT) - If the engine coolant temperature is not warm enough, idle the engine until the engine coolant
7. With the scan tool, enable the crankshaft position system variation learn procedure.
IMPORTANT: While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is
8. Slowly increase the engine speed to the RPM that you observed.
9. Immediately release the throttle when fuel cut-off is reached.
10. The scan tool displays Learn Status: Learned this ignition. If the scan tool does NOT display this message and no additional DTCs set, refer to
Symptoms - Engine Mechanical. If a DTC set, refer to Diagnostic Trouble Code (DTC) List for the applicable DTC that set.
11. Turn OFF the ignition for 30 seconds after the learn procedure is completed successfully.
Sep 11, 2009 | 2001 Chevrolet Silverado 2500HD
How to sccan small photos at a time
arrange all the small photos at one time on the small glass and you should scan it.
May 31, 2009 | Office Equipment & Supplies
HP Officejet 6310 All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
