Question about Dell 2100MP Multimedia Projector
The Temp indicator is on. what does that mean?
    Scholar:
  • 92 Answers
Your owners manual has the answer. If you can't find it in paper, it can be downloaded from Dell here: Dell 2100MP Documentation
From what I read if the indicator is solid, it means the projector is overheated. If it is blinking, it means the fan has failed and needs to be replaced.
Good Luck!
Posted on Feb 05, 2010
What does f1 mean when it flashes where the temp guage is?
It means you have a problem with the fuel injection system if you can start the bike then take it to a Suzuki mechanic. If the F1 is full on i.e.not flashing then the bike will not start normally. You still have a fuel system problem but now you have to find a way of getting it to a Suzuki mechanic. You should have a red light showing near the neutral indicator light.
Jul 14, 2014 | 2004 Suzuki GSX-R 600
What if the code doesn't work for the refridgerator once we install the board? It justs beeps which means incorrect code.
Please pay careful attention to step 5
1. Press and HOLD down the alarm keypad
2. Press and hold the Freezer Temp DOWN Keypad ( - )
3. Release the Door Alarm Keypad and wait 3 Seconds
4. The control will display PE to initate the program mode
5. Entry is confirmed by pressung the Freezed temp Down Keypad (-) once more.
6. The control will display the CURRENT program code. This value should be validated with the Program CODE printed on the unit serial plate.
NOTE: If the program CODE is correct, The programming Mode is exited by closing the Refrigerator door(s).
7. Press the Refrigerator Temp UP Keypad (+) or the Refrigerator Down Keypad (-) to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temp UP keypad (+) to select the next digit
9. Once the desired program code is displayed, press and hold the Freezer DOWN (-) keypad until the progam CODE begins flashing indicating it has been saved.
Sea Breeze
Jun 08, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
After my truck gets hot. It will not star back up right away.after it cools down it will start.The code it puts out is 15. Thanks.
Engine coolant temp sensor error (low temp indicated) code 15, this means that the coolant tempurature sensor is bad or coolant is low.
Jul 05, 2011 | 1988 Chevrolet C/K 3500
What does it mean when the temp light flashes
Blinking temp indicator means that the cooling fan has stopped, according to the service manual
Jan 21, 2011 | Hitachi 70VX915 70" LCD HDTV
1991 buick lesabre. My son said he ran throw a puddle of water and the volt and temp lights are on and its very difficult to steer. What could this be?
Volt light on indicate the altenator is not charging the battery the temp light means it's over heating and difficult steering means the power steering isn't working properly.
Common to all of these would be your serpentine belt which drives all of these items. have it replaced
Nov 25, 2010 | 1991 Buick LeSabre
Engine coolent temp circuit high input. what is
More than likely the fan switch in the radiator has failed or the fan itself has failed / is not running, so the water returning from the radiator to the engine is HOT therefore you are seeing the high coolant temp input indication. Check out the operation of your radiator fan.
If the fan circuit is OK then the water temp thermostat may very well be be stuck closed.
Thanks for using FixYa.
Kelly
Mar 20, 2010 | 2002 Kia Sedona
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Kenmore model 587 - HO flashing - what does this mean?
It means the dishwasher is on hold till the water temp reachs 160 degrees to sanitize them nasty dishs Kimosabe.
Apr 09, 2009 | Dishwashers
Please can you help why only after about a mile the engine is red hot but temp gauge is only showing middle. is this normal. YEAR 2001 WITH SERVICE HISTORY ONLY HAD SIX MONTH.
When you say "red hot" do you mean actually glowing? If so, you'd have serious trouble. If you mean only hot to the touch, that's normal - these engines run pretty warm. And yes, the gauge in the center is normal - the OEM temp gauge is a dummy gauge, only meant to show you that it's either cold, overheated, or mainly OK. Use your oil temp gauge as your main indicator - at least it's graded numerically and you can actually see the oil temp.
Jul 16, 2008 | 1999 Audi A4
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Dell 2100MP Multimedia Projector Logo
120 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
