Question about Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
  • 2,926 Answers
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Posted on Feb 05, 2010
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Mar 31, 2014 | Buffalo Tools Sportsman Series 4000 Watt...
Recoil broken
find out who manufactured the engine... if it's a honda knock off a honda recoil might work and you can get an after market one for cheap... like $30 USD or something close
Dec 26, 2013 | Buffalo Tools Sportsman 4000 Watt...
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
I need a gas tank for a 4000 watt Buffalo generator.
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
Feb 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
WHO MANUFACTURES THE ENGINE FOR THE BUFFALO TOOLS GENERATOR EX: 4000 W OR 10000 W SIMPLY PUT WHAT KIND OF ENGINE IS ON ANY OF THEM
There have been several factories in china that have made the motors used on buffalo generators, a couple of these are Lifan and J.D. as in Jiangdong.All of these motors are very similar to honda motors.The 6.5,13,and 15 h.p. motors are real brutes and hold up very well.
Jan 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
My eu 2000 watt generator (honda) starts fine, but consistently stops (like it is running out of fuel) after 10 to 30 minutes, then starts up and runs a while longer. I've taken the jet out under the...
My Honda generators have a low oil sensor that automatically shuts them down when a low oil level is detected. I keep a quart handy and top off the oil, and they start and run fine.
Dec 28, 2010 | Electrical Supplies
I have a micro quiet 4000 starts up but surges up and down , could it be just old gas making it run so bad
The reason can be:
  1. Bad or loose ignition (spark plug, magneto, coil cable etc);
  2. Water in the gas;
  3. Dirty fuel strainer;
  4. Not set on level surface;
Jul 10, 2010 | Watts Onan Portable Generator - 4000 ,...
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
New Onan 4000 watt gas RV generator cuts out
The generator engine is jetted for sea level. When you run at 24 hundred feet, it's flooding out. That's what you smell. The carb will need to be jetted for high altitude.
Jun 30, 2009 | Electrical Supplies
Buffalo Tools 4,000 Watt 6.5 Hp Portable Generator #GEN4065 Logo
256 people viewed this question
Top Buffalo Tools Electrical Supplies Experts
Bill Boyd
Lawrence Oravetz
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
