F 02 is flashing on monitor - Washing Machines
  • Dan Webster
    Dan Webster May 11, 2010
    Brand? Model number?
  • 572 Answers
Usually there is a clogged pump on most f-02 eeror codes
Posted on Feb 05, 2010
Auto adjust flashes all time
davidfoun435, Possible that unit's internal power supply is about to fail! Go here first and do some reading: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Remember this! Your cold cathode fluorescent lamp, back-lit, lcd monitor isn't any different than any other brand in it's basic engineering design and mode of operation, and when "strange stuff" appears on the screen the first thing to investigate is the "switch-mode-power-supply"
12fixlouie
Sep 30, 2010 | HP f1905 19" Flat Panel LCD Monitor
HP L107 Flat Sceen won't turn on, it just beeps and the light flashes.
crazy kit157, If pc is ok with different monitor connected then go here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading and see if something sounds familiar even though your's is different model!! Remember this, for at least the next 5 years! ALL BRANDS of CCFL back-lit monitors use the same basic electronics design and operating principles to display information on their lcd panels!!! If you still need or want more information, just return to this original post and do additional comment for us tech's to read. Povide "date of manufacture" and correct model number. rate this response ONLY if you have done your "research" first and feel that it was helpful in understanding unit's problem. 12fixlouie north of Windy City.
Sep 12, 2010 | HP L1706 17" LCD Monitor
How to mount samsung t26hd or remove the existing stand?
SAMSUNG T26HD by bsblevy - 10/10/11 11:02 AM HI I HAVE A LCD MODEL SAMSUNG T26HD HE DOESN'T TURN ON, I TRY TO TURN ON WITH THE CONTROL REMOTE ,THE LIGH LED FLASH 4 TIMES AND AFTER I LISTEN A BEEPPPP...BUT THE TV STILL OFF, BLACK SCREEM, IF YOU CAN HELP ME WITH YOUR ANSWER I WILL BE GRATEFULL, THANKS
Aug 28, 2010 | Samsung SyncMaster T240HD 24" TFT LCD...
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
How do i get the OSD lock to stop flashing on my screen?
mcadams_alic, Mostlikely a problem inside unit. After visiting this web site: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ you may then understand why your unit is acting "strange"!!! Your lcd monitor isn't any different than any other brand in it's basic design and operation. When very strange stuff starts appearing on the screen of any CCFLback-lit lcd monitor the first place all lcd technicians would look will be the monitor's "switch-mode-power-supply!!!! hope this helps. 12fixlouie
Jun 08, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
1999 Denali rough idel and driving
You should have 2 02 sensors in your exhaust system. The second one trips the ligt if your emmissions are too high abd it monitors the condition and efficiency of the cat converter. The 02 sensor in front of the muffler monitors the fuel adjustment for too rich or too lean. Now, on a cold start there ias a "cold start valve tha enriches your fuel like a choke. It can be the culprit because the #2 02 sensor is doing its job. The cold start valve can be chk'd to see if it is working by observing it.. It is behind the Throttle body. It should be clicking. Good luck and I hope this helped. Oh, wwhen the engine warms up, and you have clear the exhaust of excess fuel the light should go out.
Nov 07, 2009 | 2000 GMC Yukon Denali
My fathr gave me a hp f1703 monitor. As soon as i plug it in the whole screen flashes on and off. The light on the power cord also flashes, but if i unplug the monitor and leave the speakers plugged in the...
try another monitor i re placed my cord and the graphics card and it didn't do me any good i replaced the monitor last and it works fine now. and my speakers pluged into the monitor the monitor i bought didn't have the port for speakers so now i need to get usb speakers so check it out. hope this helps
Oct 17, 2009 | HP Pavilion F1703 17" LCD Monitor
My ViewConic Monitor has exactly the same problem as this another post? HELP!
Does it come back if you lower the resolution to the lowest and make sure the refresh rate is at 60 Hz?
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
