Question about Dishwashers
Water in the tub press drain and nothing happens press normal wash cycle Timer comes on counts down but nothing happens
  • 129 Answers
Control board
Posted on Feb 05, 2010
Bosch washing machine starts filling with water, then does nothing, timer counts down but no movment
have a technician check it out as it may be a board problem
normally the fill level switch ,when the set water level is reached activates 2 things
it stops the water in and at the same time moves the program on to start the wash cycle
so it is either that switch or the program board
Aug 13, 2015 | Bosch Washing Machines
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Bosch Integra SHU 9955US/12 - when we start wash cycle, the detergent dispenses and the tub fills with water, but the wash cycle never starts (never spins spray bars). Seems like timer is counting down,...
Sounds like your motor is burned out. The drain motor and wash motor are seperate on your machine. You can check for power going to the motor, but to do this you might have to pull the dishwasher out. While the cycle is running check for 120 VAC going into the motor. If you are getting power and nothing is happening, you will need to replace the motor, otherwise you will need to replace the motor control board located at the base of the machine.
Jan 31, 2011 | Bosch SHU9955UC Built-in Dishwasher
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
My washer stops after the wash cycle. not draning or spinning
CHECK THE RUBBER DRIVE BELT FOR THE PUMP UNDER THE WASHING MACHINE
May 09, 2009 | Washing Machines
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Dishwashers Logo
    42 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
