Question about KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator
Door adjustment The left door is out of adjustment and does not close correctly without pushing the middle bar in the correct position. The middle bar is too low. How do I adjust it?
  • KitchenAid Master
  • 8,220 Answers
Start by raising the front legs slightly to shift the directional pull of the door rearwards.
Posted on Feb 05, 2010
My LMX289885T/02 LG refrigerator's left door will not close without manually pushing the long bar into place first.
Guessing your talking about the heater. Sometimes the sprin comes loose, in the end probably will have to change it out
Sep 08, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
Degrawler wont go back in
Look at the gear inside the machine. There are 2 large teeth and they should be at 10:00 and 12:00 APPROXIMATELY. Close the door and put in the dredge drawer, then turn on the machine. Open the door and look at the gears. If they are not in the correct position you have a broken brew drive and that will have to be replaced. If they are in the correct position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Sep 10, 2010 | Saeco Royal Professional Espresso Machine
Door needs to be adjusted as it seem to be hanging lower on open
slightly loosen the bolts on the hinges enough to scoot the door into the correct position and it will stay until you tighten the bolts on the hinges. It may take a couple of tries but that is the way to do it until the door seals and closes properly =)
Jun 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Westinghouse oven does not close fully.can door hinge be adjusted?
If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Please rate my solution.
Thanks.
Oct 31, 2009 | Ovens
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
The drivers side door won't close.
open the door , look at the latch on the door , as it get older and non lubricated , the latch can stick in the locked position , i,m going to draw a picture .
when the door is open it should look like the picture , i suggest your door is in the closed position and why it bounces off as you say , take a , lets say a screw driver stick it in where the little lever thats sticking up , push the door open button on the outside door handle , pry that lever forward , if successful try it , and lubricate it , hope my barbaric picture gets the point across .
Jan 05, 2009 | 1995 Jeep Grand Cherokee
Drivers side door will not latch closed
Symptom: Door does not open or close completely Suspect Area: 1) Incorrect door installation>Adjust position 2) Defective door check assembly>Correct or replace 3) Door hinge requires grease>Apply grease
May 25, 2008 | 2006 Hyundai Sonata
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
419 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
