Question about Sony VAIO Digital Studio PCV-RZ22G PC Desktop
WHEN I BOOT UP COMPUTER, I GET A BIOS MENU SHOWING A POWER ERROR. THE POWER MENU SHOWS CPU POWER FAN AT 1467RPM, AND N/A FOR THE POWER FAN. THE "GEEK SQUAD" SAID I HAVE A BAD FAN, BUT DID NOT KNOW WHICH ONE. DO YOU?
    Problem Solver:
  • 6 Answers
The bad fan is the Processor fan, you can see it into your motherboard, you need to replace with a new one, or better check it first there might be some wires that stopped the fan to work, or simply the fan is defective.
Posted on Feb 05, 2010
Have a new Urban S71 case with Super X5DP8-G2, checked it by connecting blk and green wire on 24pin ATX power connector on the Corsair TX650 v 2.2 cpu fans and case fans all operate. Blue high low fan...
It booted up once, and now fails?
Quite likely it is defective. If it booted once, it should boot again.
Make sure the little SQUARE 4-wire plug from the power supply is also plugged into the Mobo. Commonly overlooked, and can drive you nuts trying to figure out.
Best 'o luck, Barry.
Mar 24, 2015 | Super Computers & Internet
PC not booting up.
if its windows after you push the power button keep pushing f8 till you see a boot menu / choose boot in safe mode then you can use system restore /sounds like a bad driver/ loose processor/bad fan improper cooling could be the graphics card itself
Aug 02, 2017 | ASUS P5N73-AM Motherboard
Computer continiously ask for reboot
DFirst thing to do is to UNdo everything you have just done: Memory Upgrade and CPU Cooler. If normal operation returns, try the upgrades, one at a time, to narrow down the source of the problem. I suspect the memory, as a DIMM chip not correctly set up will cause this problem. Let me know what it does, please? jaye.ellen@gmail.com
Dec 12, 2009 | ASUS P4SP-MX Motherboard
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
Power won't turn off and computer will not boot. I've removed the battery and cleared the CMOS with the jumper. lt happened after a couple of power failures at home however pwer supply has a surge...
If i understand you correctly, you are saying that you have a single beep repeating over and over with nothing showing on the monitor and no other response from your computer? The single long beep in a loop is an Award Bios beep code for a faulty CPU. This problem is not mentioned on the official website of the manufacturer. Unfortunately your only option is to replace the CPU. You might try removing and re-seating the cpu making sure you have proper cooling measures in place. Hope that helps!
Dec 11, 2008 | Biostar M7VIZ Motherboard
Cup fan erro
Firt remove the covering of the cabinet then locate a battery take it out rub it for few seconds.Place it back the way it was.Now if you have another cpu fan port on the mother board then plug your cpufans cable to it.Now restart your computer start pressing F2 ie bios settings.Now check the time and date. restart it again. See if it fixes the problem.
Please rate me> Karatela ;-)
Dec 07, 2007 | ASUS A8N-VM Motherboard
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Fan error during boot-up
Power supply, that can be the cause. Did you try disconnecting few devices to check if the CPU fan has enough power to turn itself on. Usually motherboard will have two connectors for the CPU fan, you may try connecting it directly to the power supply. Also Check through the BIOS and see if there is a setting to disable the CPU Fan monitor (Hardware Monitor??) It should be where the temps and voltages are. The BIOS in most computers has an option to monitor a CPU fan. If none exists, then the option needs to be disabled. I am assuming the error is occuring during the BIOS stage of bootup. If the error occurs in Windows, it may be that some software has been installed to monitor a fan that doesn't exist. Sometimes monitoring software comes on the motherboard CD and someone may install it, thinking it is a driver. It is not necessary. Good luck!
Jan 13, 2006 | HP (D9820-60007) Motherboard
Sony VAIO Digital Studio PCV-RZ22G PC Desktop Logo
147 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
