Question about Asrock 775Dual-880 Pro Motherboard
Systemax desktop venture
I cannot find where my memory chip is, and how to install a new one
  • 97 Answers
Where can i find specs for my systemax venture desktop
there are specs inside the case, on the bottom, for my systemax venture. there is also a serial number on the back of the tower, on the outside; however, i believe that the systemax desktops were actually assembled by tiger direct.com.
May 20, 2014 | Systemax Computers & Internet
Setting up windows XP on Systemax venture computer says set up can not access this disk
If you installing a new windows you should first delete all partititons and then create one and install windows on that. Remeber all data on your harddisk gonna get deleted. So press d to delete and then c, then enter on the new partition
Apr 06, 2012 | Systemax Ascent PC Desktop
I need all drivers for my systemax venture
Use Driver Genius Professional software this will automatically identify the hardware and install the updated drivers for ur system
Apr 24, 2010 | Systemax Venture PC Desktop
Rolling reboot problem, computer reboots for know apparent reason.systemax venture p4
Probably getting too hot or HDD problem.
If too hot you may take of the case and blow out the system with an air compressor (just take it outside away from clean things). Also while it is apart clear away any lint debis from the CPU fan & heatsink area. Leave the case off and hookup your system again. This will do two things, 1.) give you better airflow to test the heat theory and 2.) give you a chance to peek at the CPU fan to see if it is moving well. Depending on your motherboard you may have a sensor monitor in the bios which will allow you to check the tempature of the CPU as well as the fan speed.
If it is a Hard Drive problem listen for a noisy drive arm (clicking sound). Lastly if it's a memory problem you can tell by swaping out the chips. But i would lay odds that it's a heat issue. Hope this helps, Best Regards, -md
Nov 10, 2009 | Systemax Venture PC Desktop
My pc dont start
The problem identified that your system wont start. By solving, let begin from the very the very start. 1. be sure that power supply function well. u can test PS by changing temporary identified functional PS. if u sure that PS is good then, examine processor. remove memory. switch on system w/out memory if hear beeping. u are sure that processor is working.if not then something wrong with your processor. if beefing then insert memory. if not solve, examine memory clean it very well. and insert. if same problem replace memory. notify me if more problem identified. we will continue.....
Dec 14, 2007 | Systemax Venture PC Desktop
Ram memory
the problem may be that your new memory is not compatable with the current memory and board, the easiest way is to remove your memory and just install the new memory and try all slots, if you get no boot then you know the memory is not compatable.
Sep 30, 2007 | Systemax Venture S519J (988868) PC Desktop
Systemax
Well the SystemMaxPC.com website is next to worthless. But, you might try http://www.cpuid.com/cpuz.php run this app and see which motherboard you have, then maybe find manual on manufacturer's site. CPU-Z will also show you what processor and memory you have currently, and more.
Aug 04, 2007 | Systemax Venture S519J (988868) PC Desktop
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Asrock 775Dual-880 Pro Motherboard Logo
62 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
