Top load washing machine drum froze. What to do???
  • 3 more comments
  • john_harriso Feb 05, 2010
    Thanks for helping me out. Here is the deal. The washer was in the middle of a load, agitating and just stopped. No noise, no warning. The drum is stuck and the agitator is very loose. The advise you gave sounds right but how do I access those parts?
    Kenmore series 80 heavy duty. For parts I call Sears. But how do I check the idler pulley, and the transmission?
    You still here?
    Thanks for using FixYa. First thing is to check the idler pulley, also check the transmission for your washer. It seems that the spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Please do accept the solution if the issue is resolved or else revert for further assistance.
    How do I check the idler pully and the transmission to see if they are good or need replacing?
    This is a Kenmore series 80 top load with a frozen drum
    Thanks for the assist.
  • Washing Mach... Master
  • 8,220 Answers
Thaw it out: use these manuals
Posted on Feb 05, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith Feb 05, 2010
    Please tell me the manufacturers name and model no# for your washer for information on how to access parts.
    Thanks
    Rylee
  • Rylee Smith
    Please click on this link on how to take apart your Kenmore Top Load. Please check the picture for better understanding of parts:
    Thanks
    Rylee
  • Rylee Smith
    It takes time to send some information, please check the comment that I just sent.
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
  • 112 Answers
SOURCE: loud banging on spin cycle frigidare washing machine model no. fws235rft2
If this is a front loader this is a common problem. Unfortunately, it is also a very extensive project (about 8 hours). The tripod supports that attache the drum to the center spindle commonly break. The remedy is to replace both the front and rear tub, and the basket as well. It is also recommended that you replace the drain pump as well. Generally, they will cover the parts (not including the drain pump) under warranty but the labor will be a customer pay.
Posted on Oct 19, 2008
futureloginn
  • 734 Answers
SOURCE: Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
skrbin
  • 121 Answers
SOURCE: washing machine after water load the drum
must check water level device,if You do not know what is this or where is on machine then call a service.Maybe is hose is precipitate from device.
Posted on Feb 17, 2009
RescueTech
  • 145 Answers
SOURCE: I overloaded my washing machine!!
Hi Tracy, welcome to Fix ya.
I believe know exactly what happened here- one or more of your tub support rods has broken and that caused the tub to drop down. Those are actually pretty easy to change yourself! Lift the lid, look for two plastic caps, one on each side, that cover the screws the secure the washer top to the cabinet. Pop the caps off, take out the screws. Now the whole top can be opened up (it's on a hinge of sorts) and now you can see the main basket/tub assembly. The rods fit in a recess on the tub at the bottom and on the top of the rods, the triangular plastic sits in each corner of the machine. There are no tools needed, these rods come off very easily.
You can get a set here: (They are sold in sets of 4 and should be replaced as a set)
http://www.fisherpaykelparts.net/ecart/item.php?item_id=218&category_id=46
I hope this info is useful to you.
Posted on Feb 28, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
My clothes doesn't get agitated in the wash or rinse cycle. I don' t see how it can get my clothes clean this way
Need more info, what kind of washing machine do you have? I am going to assume you have a front load washer. There is no agitater, instead the drum rotates, as the drum rotates the cloths roll up the side of the drum. When they are almost to the top of the drum they fall and the weight of the cloths themselves provides the agitating action. I have been using a front load washer for years, wouldent think of using a top load. Hope this helps..
Oct 08, 2015 | Washing Machines
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
Dryer is froze(drum)
if u can hear the motor turning but the drum is not you need to replace the belt around that gos around the drum
Feb 27, 2011 | Whirlpool LTE5243D Top Load Stacked...
The drum won't spin during the spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Oct 04, 2010 | Maytag LAT3600A Top Load Washer
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint wma30. Drum not draining water. Have
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
The drum will not spinn?
heatman101
May 20, 2010 | LG WM1814CW Front Load Washer
My kenmore 80 series washer will not agitate or spin, water flow in and pumps out fine
it is a drive problem consisting of several things.. bad motor, drive belt slipped off, clutch froze up, drum brake engaged, or no power to the motor. have it checked by a professional.. good luck
Nov 15, 2009 | Kenmore 24032\24036 Top Load Washer
Drum is banging on wash cycle.
Hi
I am not too familiar with KitchenAid products as we dont have them in Australia. However most front load washing machines have the same basic set up.
Open the top hatch and also the back panel. Check the suspension springs on top of the drum and also the shock absorbers underneath the drum.
Make sure they are ok and non has come off or broken during the move.
Also make sure that the counter balance bricks or blocks are not brocken or loose.
Good luck.
Ash
Oct 31, 2009 | KitchenAid KHWS01PMT Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
