Question about Microsoft Xbox 360 Console
Xbox reads games as dvd - Microsoft Xbox 360 Console
  • Bhautik Joshi
    Bhautik Joshi May 11, 2010
    If your Xbox 360 is reading your games as DVD, you need to confirm if the discs are copied ones or genuine Xbox 360 games, because copied games do not work on a original Xbox 360
  • 281 Answers
This can be caused by a dirty laser in the drive. Try cleaning the laser with a q-tip and alcohol. If this does not fix the problem, the laser may need to be replaced. Contact Microsoft and see if the unit is still under warranty.
Posted on Feb 05, 2010
SOURCE: Xbox reads game as DVD
When this happens this means that your laser lens is going bad. You can order a new lens off of Ebay and replace it or order a new DVD drive of the same model and replace the circuit board with the one in your current drive. The reason you need to replace the board if you order a new drive instead of just a laser lens is because the firmware of the DVD drive is mated to the motherboard. You can not just replace the whole drive and get it to work.
Posted on Feb 10, 2008
cyclik
  • 10 Answers
SOURCE: my xbox 360 drive wont read games it will only dvds and cds
Your laser either needs to be cleaned or is going bad. I have seen this many times before. Try taking the drive apart and cleaning the laser aperture with 91% alcohol and a cotton swab (carefully). If that doesn't work then you need to replace the laser (or get a new drive).
Posted on Jun 08, 2009
SOURCE: xbox 360 reading games as DVD
you get a ******* life
Posted on Nov 22, 2008
  • 154 Answers
SOURCE: xbox only reads dvd not games
The laser lens might be dirty. You can clean it off with a cd /dvd lens cleaning kit or you can "carefully" clean it off with alcohol and a q-tip. If you use a q-tip make sure it's not saturated with alcohol, you only need a little.
If this is the same console that had the rrod problem, also check to make sure the SATA cable is seated properly.
If you still have the problem after cleaning the lens, you'll need to get a new drive. Before you run out and buy a new one, check to see which manufacturer made your current drive and note the model number.
As mentioned already, the new dvd drive will need the same dvd key as the old one. The easiest way to do this is to take the circuit board from the old drive and swap it with the board in the new drive.
Posted on Aug 22, 2009
  • 11 Answers
SOURCE: xbox 360 will only read dvds shows reading dvd
This means the DVD key went bad. If you flashed your firmware or have a jtag, this is an easy fix, but otherwise I would check craigslist or call Microsoft
Posted on Aug 04, 2010
Xbox 360 will only read dvds shows reading dvd
Jul 23, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
DVD
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
The DVD issue normally happens as you will find that it can still read DVD's!
You will need to stop the heat to read games.
Feb 10, 2010 | Microsoft Xbox 360 Console
Xbox doesnt read games or dvd
If your Xbox 360 is not reading games you need to stop the heat build up getting to the chips on the back of the DVD drive.
To do this use a good Xbox 360 repair guide or send it in.
Feb 03, 2010 | Microsoft Xbox 360 Console
Why does my xbox say my games are dvds
Are you using copied CD's of Xbox games, Original Xbox 360 would read such copied game discs as normal DVD's and would show a message as "Play DVD"
To play such games it requires the Xbox 360 DVD drive to be flashed, which is called as a Softmod, if you do so you would be banned for playing on Xbox Live and such act is prohibited since it accounts to game piracy
Dec 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 arcade pal game read error
You will get this error when your laser is in need of replacing. The other message you will get is open tray. If your system will play regular movie dvd's but not games then replace the laser. You can find them pretty cheap on ebay.
Sep 11, 2009 | Video Game Consoles & Games
Reads games as DVD
Does it happen with all your games or just one and which game
Mar 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 game reads as DVD
change your laser or replace drive
Feb 14, 2009 | Microsoft Xbox 360 Console
Gears of War Disc
Some of the Xbox 360s have been known to have issues with their DVD-ROM Drives, On Older Xbox 360s The actual Drive has been known to cause slight scratching and scuffing to your Games.
If your Xbox 360 is having problems reading games, their is potentially a problem with the DVD Drives Laser, i had this issue last year with mine, Out of the blue the DVD Drive stopped working and wouldnt read discs. The i would suggest Calling Up the Xbox Customer support Center for your Country (numbers Available on www.xbox.com/support) and explain your problem to the person on the end of the line.
The only solution is usually to return your Xbox to microsoft Free of charge, which will be either repaired/replaced and sent back to you.
Also, once the solution is solved, it is important to NOT leave Games/DVD's In the Xbox's drive when not in use, Especially when moving the Xbox around as this can knock the laser and cause a fault ! their is only ever a DVD in my xbox drive when it is in use, i take mine out all the time to help prevent these sorts of problems.
Hope This helps !?
Oct 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 doesn't read dvd'd
dvd drive is getting weak you can try to clean it
or replace
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
282 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
