Question about Roper FGP305 Gas Kitchen Range
I used my oven a couple of days ago, and ever since I can smell a faint gas smell. I opened up the oven and it's definitely coming from inside the oven, not from below where the actual gas pipes light.
  • Roper Master
  • 8,220 Answers
Your pilot light must have blown out. Get a match and light it.I looked up your model number and your oven uses a standng pilot. It is attached near the rear of the burner. Check out these photos HERE
Posted on Feb 05, 2010
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
I have a frigidaire gallery propane stove. I just bought it a couple weeks ago. We converted in from natural gas to propane, the top works great but the ovens gives off a terrible smell whenever we use it....
THAT IS VERY COMMON,YOU HAVE TO EITHER CHANGE THE ORFFICE ON THE OVEN AS WELL OR ADJUSTED,TURN IT DOWN CLOCK WISE TO REDUCE THE GAS FLOW,THEN OPEN THE AIR FLOW WINDOW ALL THE WAY,ADJUST 1/2 A TURN AT THE TIME .....AND PRESTO
Apr 21, 2013 | Kitchen Ranges
Beko OFT12300X double oven top oven getting exceptionally hot inside when only the bottom oven is on
I know of nothing unusual about this, the oven vents some through the top burner.
May 19, 2017 | Ovens
I have an ES340 gas self cleaning oven. I smell gas when I open the oven door. I checked all the connections in the back and the ones behind the back panel, and none are leaking. Are there connections...
Hello tds. It is not uncommon to smell gas when you open an oven door. That said, if the amount of gas you smell is stronger than it used to be call your gas company. They will send out a technician, free of charge, to check your stove. Joe
Thanks for choosing Fixya!
Jan 13, 2011 | Frigidaire Ovens
When I turn the oven on, there is a chemical smell. I'm not sure how to describe it, but it makes the oven unusable. I am the third owner of the oven and once a few years ago did use the self-clean...
you check your oven inside? pls check inside i think the smell is came from inside the oven mostly the oven is not claen properly especially in upper inside the oven,that why evry time you use smell is coming coz of heating the dirty inside.
Dec 17, 2010 | Microwave Ovens
Intermitent gas smell
yes it is possible. a faint smell now and again from a gas stove is normal, as it has many burners to and oven. if smell is not constant, nothing to worry about.
Sep 09, 2009 | Kitchen Ranges
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Oven takes a loooong time to reach target temperature
sounds as if your bake igniter has gone bad, common issue witrh all gas ranges, part number 12400035 this will cure your problem, comes will everything youll need including instructions
Nov 24, 2008 | Maytag MGR5751AD Gas Kitchen Range
Oven does not heat
Ignitor, good luck getting the old one out. That is why I'm here.
Jun 26, 2008 | Tappan TGF320 Gas Kitchen Range
Roper FGP305 Gas Kitchen Range Logo
166 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
